Question about Kenmore 24032\24036 Top Load Washer
Repair manual model 110. I have a model 110-82980820 washer. How do i get the agitator appart to replace the agitator dogs? I have the agitator out of the machine already.
jgwhomeequip
  • 1902 Answers
SOURCE: Washer making rubing noise while turning
On the back of your machine you can remove the back panel think it is about 8 screws. Once you get the back panel off look closely at the motor. Motor mounts, gears, clutch, brake, and if need be take the bottom apart and look at the main bearing on the bottom of the drum to make sure that hasnt gone bad
Posted on Feb 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dog Agit replacement on a Kenmore washing machine?
Take the top cap off the agitator.
Remove the plastic cover inside.(use pliers to pull it off).
Remove the bolt.
Pull the top half of the agitator off.
Replace the dogs.
Re-install the agitator.
Posted on Mar 08, 2009
  • 188 Answers
SOURCE: kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Posted on Mar 12, 2009
  • 107 Answers
SOURCE: washer is making a grinding noise. It want spin or agitate.
Coupler between the motor and gearcase is broken...Remove end caps and phillips screws from console. Pull console and flip up..Unplug lid switch and remove gold looking clips on both sides. (push screwdriver strait down and press away from you)..Pull cabinet towards you and remove. Pump is in middle of front by floor..Remove 2 clips with flat head and pull off. ( leave hoses on pump). Remove 2 1/4" screws and remove motor clips with flathead. Motor will fall so hold hand under it. Check plastic and rubber coupler between motor shaft and trans. I guarantee, its broken or worn out..
Posted on Mar 13, 2009
  • 351 Answers
SOURCE: I havea Kenmore Series 70 Washer. I top agitator
Take the softner dispensor out then you have a clear cap, remove that it just comes right out.
Then you will see a 7/16" screw take that out. Then the top will easily come out.
Very easy can do it in like 2 mins.
The hard part is lineing it all up to put it back in. Let me know if you need any more help.
Posted on Apr 19, 2009
How to remove the agitator
Washer Agitator Repair Agitator Not Working ... - YouTube
? 7:51
www.youtube.com/watch?v=yxfDICZ0Ses
Apr 21, 2010 - Uploaded by applianceassistant Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
Sep 14, 2015 | Washing Machines
I have an older model (bought it about 15 years ago) top loading Kenmore washer. I noticed that the spindle that is part of the agitator doesn't move as much as it is supposed to. In fact, if you...
That sounds as if the parts called the agitator dogs are worn out and thats a pretty easy thing to replace the dogs and fairly inexpensive (the parts are less that $8.00) this tip i wrote explains how to replace the agaitator dogs. http://www1.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Sep 18, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My kitchenaid washer is not agitating normally, barely agitates and I'm looking for a manual for my model KAWE900TAL0, is there one available?
Hello.
Repair manuals are indeed available but are $15-20 and take a average of 2 weeks to arrive.However bing very experienced in all brand of the Whirlpool washer which makes the Kitchen Aid brand,i believe 1of 2 things will cause that.
Firstly if it agitates on the lower portion and its just the upper barrel of the agitator that isn't working plus it also spins the water out normally and the clothes dont come out dripping wet,its going to be the parts in the upper agitator called the dogs because they appear to look like dog paws,are wore out and not catching. I have included 2 youtube videos showing step by step how to replace the dogs and the part ill talk about in a minute. The dogs could be replaced seperatly or the kit as shown in the video,ill give you part numbers at the end of the email.
The other thing it could be espically if it doesnt agitate at all AND also doesnt spin well leaving the clothes dripping wet when removing them to the dryer.will be a broken motor coupler and i have included a video for replacing that as well
The part that it turns out to be could be purchased at your appliance parts store or on there at REPAIRCLINIC.COM or elsewhere on line at;
searspartsdirect.com
appliancepartspros
apwagner.com
midwestapplianceparts.com
http://www.youtube.com/user/RepairClinic?v=0GQh8JLqVv8&feature=pyv&ad=5457341621&kw=agitator dog replacement video
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler motor coupler video
PART NUMBERS
dogs alone 80040
complete dog kit 285811
motor coupler 285753A
Good luck,i hope i have been able to help you fix your washer,
Gene
Aug 13, 2011 | KitchenAid Washing Machines
Whirpool Topload Washer: Agitator
well if you grab ahold of the agitator turn it 1 way and real quick back the other way and your able to turn it back then the dog ears are wore out and is easy to replace, can get them from your nearest appliance shop or order from Repairclinic.com, you can also get a manual from them if needed!
Feb 10, 2010 | Whirlpool LBR5432L Top Load Washer
The top part of the aggatator does not turn
Washer has trouble agitating... Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid.
Replace the dogs its a easy fix for you
Dec 28, 2009 | Whirlpool Washing Machines
Washer won't agitate
First, see the Sears parts site for washer model # 110.22952100 which I believe is your model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22952100+
Look at the section containing the agitator and you should see how the parts fit.
Also see the following for an illustrated description of replacing the "dogs"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore Washing Machines
How do I remove the agitator on my model #11020922990 washing machine to inspect/repair the agitator dogs?
The following link explains how to access and repair/replace the agitator dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a fairly simple repair, but if you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Washing Machines
Agitator doesn't agitate - kenmore model 110
how old is the machine? agitator dogs in agitators have only been used for the past 15 or so years. sounds like you need to take the agitator out and replace the 4 dogs in the top of the agitator. not a costly repair.
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Washer 70 Series - agitation problem
Check out this video if the top just spins this is your problem and directions to repair it.
http://video.google.com/videosearch?hl=en&client=opera&rls=en&hs=Rfi&q=how%20to%20change%20whirlpool%20agitator%20dogs&um=1&ie=UTF-8&sa=N&tab=wv#
Sep 06, 2009 | Kenmore 22422 Top Load Washer
Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
Jan 22, 2008 | Whirlpool LSR6232J Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
