Question about Kitchen Ranges
T.J HARRINGTON, GAT AIR PISTOL
Harrington richardson 243 modle sb2 ultra would like to know the value of this gun
H&R SB2 Ultra .223...whats it worth? ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Apr 9, 2011 - 9 posts - ‎4 authors ... i can get for it. Its an H&R SB2 Ultra .223 with a Bushnell 6x-18x,50 Banner... ... NIB - this model in that caliber sells in the $279 - $290 range.
Harrington For Sale - GunBroker.com
www.gunbroker.com/Harrington-Firearms/Browse.aspx?Keywords=Harrington...
  1. Cached
  2. Similar
H&R Harrington & Richardson SB2 Ultra 243 win ... Harrington and Richardson Handi Rifle 243 Win ... H&R Model 158 30-30WIn -LIKE NEW-single shot.
Harrington Richardson Rifles For Sale on GunsAmerica
https://www.gunsamerica.com/Search.htm?C=325
  1. Cached
24 Listings - Beautiful H&R (marked Wesson & Richardson) Model 1871 Buffalo Classic ... Harrington & Richardson Handi Rifle; SB2; in .243; 22-inch barrel; adult ... Harrington richardson 243 modle sb2 ultra Google Search
Dec 02, 2016 | Harrington & Richardson H&R Superlight...
How can i turn a spring air soft pistol into a semi auto pistol ?
By selling it, pay a difference and get another one.
May 24, 2014 | Computers & Internet
How to put in co2 cartrige in a.177 cal 4.5mm
Hi wendyavery...
The Marksman 2000K does not use CO2 cartridges, it uses a spring to act as the "power plant"
Go to the following webpage and check it out
Please rate me
Bud
http://www.pyramydair.com/s/m/Marksman_2000K_Air_Pistol/644
Oct 06, 2012 | Marksman 2000K Air Pistol - 0.177 Caliber...
I have a crossman 1377 (177) cal pellet pistol. Is it ok to shoot BB'S in this gun? Does it damage the rifling in the barrel? Thanks, Gary
yes it safe to shoot bb,s in the 1377 pump pistol,i have 3 of them they actually shoot true'er and with more vilocity
Sep 19, 2011 | Crosman 1377 177 Single Shot Air Pistol
Looking for an o-ring for beeman tempest pistol where pellet is inserted
Hi orichtero...
Take the air gun to the nearest roller bearing seller, they will have o rings also...they will be able to fit the right o ring for your gun for you
Please take time to rate me
Aug 11, 2011 | Crosman 1377 177 Single Shot Air Pistol
Air pistol c02 replacement
Well that takes me back! I have an old Daisy 1200 -- essentially the same pistol in a different brand.
My Daisy has a hand-turn screw to hold the CO2 cartridge in place, and you have to tighten it quickly until the leaking stops. It does this by pressing the cartridge up against a nylon washer to form a seal (and of course pushing it into the piercing pin to get the CO2 out!)
With age, I'd expect that nylon washer to get stiff or crack, making it harder to form a good seal. You don't need an exact replacement part, but if that's happened to yours then you will need to replace it with something more-or-less the same size as the original.
May 30, 2010 | Crosman 1377 177 Single Shot Air Pistol
CO2 Pistol magazine replacement
I have an pro77 co2 bb gun.for some reason when I pull the the trigger
the hammer won't deploy.can you help me fix the problem........
Mar 10, 2010 | Air Tools & Compressors
Need repair parts for a Beeman model 800 or 850 air pistol
The only Airgun repair shop I know of is in Minneapolis, MN.
B & B Supply 4501 Minnehaha Ave So. Minneapolis, MN
Website: http://www.b-bsupplyco.com/
Hope this helps, mark the Gunsmith
Please leave feedback, Thanks!
Jan 12, 2010 | Beeman Optics
Info on repair crosman 150 air pistol
This is better known as a Crossman Air Pistol and it is powered by co2 cartridges that will not last too long once puntured/installed in the pistol, they tend to leak out within less then a day if not being used so try to use the cartridge once you have it in place.
Some fire BB's and some fire pellets.
Wear protective eye wear and clothing and always fire down range never point any pistol at anyone when handling it keep your fingers off the trigger and point up or down range.
Happy Target Practicing!!
Sep 29, 2009 | Computers & Internet
Crosman 1377 air pistol
the seal must be broken. send it back to whom you bought it from and get an exchange
Oct 22, 2008 | Crosman (4032)
Kitchen Ranges Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
