Lg 50pb2dr turned it's self off if i press the power button it goes to turn on the turns off after 3 seconds again
My wife said she heard a pop noise just before it turned off
snakehead
  • 1074 Answers
SOURCE: Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Posted on Jun 23, 2007
SOURCE: Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Posted on Oct 03, 2007
  • 5 Answers
SOURCE: LG LCD 37'' standby problem
if you want i will buy the tv from you
Posted on Feb 23, 2009
  • 136 Answers
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Posted on Aug 08, 2009
fieldy14
  • 456 Answers
SOURCE: LG Plasma 42pc3d turns on, pops, turns off
Its very likely that you need to have LG perform a sodtware upgrade on your unit. Contact LG and see if your tv is one of the applicable units with software upgrade issues, please let me know if it works. Good Luck.
Posted on Dec 03, 2009
Change language on WMAOD 743
Try this:
1) plug into the power supply and turn on at the socket.
2) do not press the on/off button on the machine at all.
3) press the 3 buttons marked "reduced creases+mini load+time saver" and hold down together until a beep is heard. approx 5 to 10 seconds.
4) leave for 10 seconds.
5) turn on with the on/off button.
6) you are ready to run through the language menu again.
7) select required language by pressing the "child lock" button once.
Nov 16, 2017 | Computers & Internet
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Lg flatron 192ws ....... when i power on the display, it shows the display for 2-3 seconds and then goes off, and the power led still remain lid. i press the power button to turn off the power led and...
Possible causes of "2 seconds to black" can be
a) bad caps
b) bad ccfls and/or ccfl wiring
c) bad inverter transformer
d) bad ccfl sense circuitry
All are discussed in more detail starting with post #13 and #14 at
http://www.badcaps.net/forum/showthread.php?t=10419
Also look here. https://www.badcaps.net/forum/showthread.php?t=14144
Nov 01, 2017 | LG L192WS LCD Monitor
Sher3sc@aolI have a Mitsubishi hd 1080 series and the power button goes off as soon as you turn it on. How can I fix this?
The set has a self check feature: when green light (power) goes out on the front of the set press and hold both the menu and input buttons at same time for at least five seconds and release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it several times.
If the set was unplugged you will have to try to turn it on and then do the check.
2,2 is short protection and usually means (98%) convergence problem.
1,2 is no error detected etc.
Let me know what you find and I will help.
SD TECH
May 12, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Will not print. turns on lights up makes noise
There are two self tests you can try to test the printer. With only the black cartridge and on sheet of paper. Disconnect the printer from the computer and unplug it. Plug it back in and do the following:
Press and hold the power button. At the same time, press and hold the Ready/Insert button. Release the power button, but keep holding the Ready/Insert button. After 4 seconds, release and press the button again and release. It should print a one page diagnostic test.
The second self print test using all 4 cartridges. Turn the printer on, press and hold the Ready/Insert button for a few seconds and release the button. The test will use all 4 inks.
Jan 02, 2010 | Alps MD 1000 Thermal Printer
The power button is flashing red...
It ur power board,Tries buy it replaced it ur self it pretty easy.
Nov 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Televison & Video Logo
Top Televison & Video Experts
