Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Kenmore Washing Machine
By horvasa on Oct 07, 2007
The washing machine leaks from bottom when filling up in the beginning and on the rinse cycle.
Same Problem
Nov 04, 2007
-   I have a stackable washer/dryer. Its Kenore, not sure of the exact model. When I do a load the machine leaks from underneath when its draining. We checked the hose from where the water drains, but the water is not coming from there. Please help.-   leaksalot
Best Solution
posted on Oct 28, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If not a hose leak, check for leakage around the water pump.  On our top-load Kenmore, the leak showed up at the front right of the machine.  Water was leaking where the pump slides onto the motor shaft.   Replacement of pump consists of: (1) unplug power cord and then remove 2 screws at corners of the dial/control panel to tilt it back, (2)  unplug wiring harness, (3) remove two spring clips holding white metal console to the frame then tilt console forward and remove, (4)pump was in front of machine with two black hoses attached via hose clamps - remove the spring clips at top & bottom of pump and remove the two hose clamps, (5) slide new pump onto shaft and reassemble in reverse order.
Solution #2
posted on Oct 08, 2007
Somewhat Helpful)
premm
Rank: Guru
Rating: 93%, 3332 votes
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Wondering about the GE GCVH6500K front-load washing machine? Cannot find any reviews etc online.
Answer
no light at power button stoppped midway wash, fuse ok, full of water indesit w133s washing machine
Answer
water wont drain from wash. Wont spin or drain stuck on wash setting. Cant get filter cap off.
Answer
i need manual for whirlpool front loading washing machine AWZ 410-1000
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
