Audio output from sharp t.v.aquos lc42a48l how does it work
  • 979 Answers
SOURCE: hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Posted on Nov 26, 2007
  • 86 Answers
SOURCE: Blink on Sharp Aquos LC-32D43U
If your using a HD converter box, there is usually a blink when switching from an HD channel to a non HD channel. It is just adjusting from different pictures modes such as changing from a 480i channel/show to a 1080i channel. If this is the case, its perfectly normal.
Posted on Jan 20, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
  • 8457 Answers
SOURCE: Sharp aquos LC-42D62U. Have audio but no picture.
Ur LCD inverter is dead,must replaced to get the picture back.
Posted on Dec 02, 2009
SD Tech
  • 14553 Answers
SOURCE: sharp aquos lc-32le600E connected to PC video is fine, but no audio, any advice? Thank you in advance
Good job---Thank You for letting us know you got it and thanks for using FIXYA.
Posted on Mar 16, 2012
My sharp aquos tv LC-60LE632U has picture but no sound, What can be done?
Check the audio 'output select' under the Systems Settings menus. The output may be set to 'variable'. Set it to 'fixed' so that the audio runs through the speakers.
Oct 12, 2014 | Sharp AQUOS LC-60LE632U 60" LED TV...
How do I connect my Sharp Aquos to my audio system-- TV to preamp and so on?
hi,
you can connect th analog audio output of your tv to ur preamp's any of the analog audio input, if it is a stereo preamp. if u have a AV receiver, then connect the digital audio output ( optical )of your tv , to any one of the digital input of ur AV receiver.
ok
Dec 20, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Can i connect speakers directly to Audio R L output on Sharp Aquos LC?
NO. The outputs are at line level. You'd need an amplifier between them.
Oct 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC46lE700UN How do I adjust the audio. Manual says that the Output Select to Fixed, but it still does not allow me to adjust the audio
If the RCA audio out put is set to 'FIXED' it means the signal at the RCA jacks will not be controlled by the Volume control of the TV, but the TV speakers will still be controlled by the TV volume control, if you want to make the RCA AUDIO out to be adjustable by the TV volume control, you will have to set it to 'VARIABLE'.
Nov 03, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
No sound from TV - Sharp TV LC-32GPIU
Check to make sure you have the speakers tuned on in the setup menu, and you are not in sap.
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Aquos LC-37D64U - I've got a Motorola DSR505 satellite receiver with a DVI output. As per the Aquos' manual, I hooked it up with a DVI to HDMI adaptor cable and ran separate stereo RCA from one of the...
You have it hooked up right. I found something on page 26 of your manual. Look at the HDMI setup section. I think that maybe the problem there. It's an audio select option for input 5.
Let me know if it works.
Apr 23, 2009 | Sharp Televison & Video
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Setting up sharp 46
Try to isolate the problem.
Try plugging in another source such as a DVD, is there audio? If yes, problem may be with the optimum box. If no, most likely a problem with the TV.
Also, if you are using HDMI with the HDTV box, make sure the box is set to output audio through HDMI.
Feb 10, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
