Question about Bunn GR10 Coffee Maker
Gevalia coffee maker
Okay, I accidentily put a scoop of coffee in the water reservior and now my coffee pot is not working properly. it is making the noise that you usually here at the end of brewing (through the whole cycle) and does not make the twelve cups that i put in. How do I fix this myself? thank you Jill
  • jillnmark Oct 08, 2007
    Thank you so much!
  • 625 Answers
The whole thing has to be taken apart. remove the two screws on top, disconnect the warmer heater. In the tray remove the brass reducer and gasket. lift out the tray. disconnect the two spade terminals going down to the warmer heater. disconnect the electrical leads to the main element. remove the sprayhead and the nut that is below it. remove the screws that hold the tank in place. pull the whole tank out. it holds three potfulls of water. remove the plastic bushing and gasket pieces for the thermostat. remove the thermostat capillary [ be careful with it] remove the screws holding the element and cover. pull out the element. remove the water and clean the inside. pass the cleaning spring through the main tube.
Posted on Oct 07, 2007
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
My Gevalia CM-500B turns off before completely making a pot of coffee.
I dropped some coffee inside the coffee maker and it got clogged, I took it apart and I found out where the problem was but as soon I took the plastic tube with two small pieces that I believed is the filter,well now that I want to put it back I can't remember how the two small pieces go, please can you tell me how can I do this.
Nov 29, 2010 | Gevalia CM-500 12 Cup Coffee Maker
The glass coffee pot is broken on the xcc 12 model -- where can I find an economical glass pot replacement. I have the metal frame
Gevalia does not make coffee pots. The last one I had came from Melitta but with Gevalia's name on it. I got my replacement pot from Melitta. I would not suggest that road - way too expensive. Check Walmart or Target for a Melitta replacement.
Nov 24, 2010 | Gevalia 35411 / 50433 Coffee Maker
How much coffe to make a pot of coffee
usually you would put one less scoop of coffee than water. so if you want 12 cups of coffee you put 12 cups of water and 11 tablespoons of coffee
Aug 05, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
How many scoops of coffee for 36 cups?
the traditional wisdom is one scoop per cup and one for the pot
Dec 13, 2009 | West Bend (58036) 36-Cup Coffee Maker
Coffee maker stoped working
  • Make sure the power supply is all rite (if not try with different socket)
  • If your able to seee light..then try re-programme it using buttons.
  • Still if you face same issue ..i request you to call technician.dont try any thing,Give it to safe hands
  • Thanks
  • Jul 22, 2009 | Gevalia 50041 / 50443 Coffee Maker
    Need to replace the glass coffee pot
    i definitely know the answer to this one..... my gevalia glass pot broke one morning. I called the gevalia customer care number and the rushed me out another immediately!
    wow! and I thought they would charge me.... I paid nothing! great coffee! great customer service!
    Jun 06, 2009 | Gevalia CM-500 12 Cup Coffee Maker
    Gevalia xcc-12
    clean with limeout, or coffee maker cleaner, I used about 1/2 cup liquid limeout 2 cups water, run through bout 2 times, be sure to run several pots water through after cleaning,
    Apr 25, 2009 | Gevalia 50041 / 50443 Coffee Maker
    I have a broken pot for CM 500.
    I have a brand new carafe White for the Gevalia white for sale contact me
    Oct 27, 2008 | Gevalia CM-500 12 Cup Coffee Maker
    Bunn GR10 Coffee Maker Logo
    51 people viewed this question
    Top Bunn Coffee Makers & Espresso Machines Experts
    Kelley Hopper
    Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
