Question about Samsung SWA-4000
Swa 6000 I changed my wireless receiver. Now I cant get it to link with my Blu ray. Light is flashing Blue Wont Stay on Solid
5 Suggested Answers
SOURCE: problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
Posted on Nov 22, 2008
SOURCE: SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Posted on Apr 30, 2009
aroracaty2
  • 503 Answers
SOURCE: Hi I just set up Samsung SWA-4000 and for some
This means that its lost the connection to the wireless transmitter, the error means Rear CHK or check hence RCHK. Seems that if the unit is not quite in line of sight the connection can be flaky. I would check the positioning of the reciever. Try moving it, see if you cant get a better connection.
Posted on May 18, 2010
issken
  • 1472 Answers
SOURCE: Can't get netflix to run
whasteyac
In regards to you problem connecting to your wireless router. Are you able to see the network and do you have security enabled on it. It is possible that your blu-ray player does not support that security. Also how many wireless devices do you have in your house connecting to the router.
Just to clarify that you got it to work with the wired cable. Also please include the make and model of your router.
Issken
http://www.fixya.com/users/issken
Posted on Sep 18, 2011
My SWA-5000 is not connecting to my main unit, which is a samsung blu-ray home theater system. I have already tried what it has said on the manual, but it still wont turn on, it is just on standby. Please...
start with the main unit turned off. Press and hold the button on the back of the swa-5000 module until the light on front starts blinking fast. Then point the remote at the main unit and press 0-1-3-5-ENTER. The standby light on the main unit should turn off then back on. Turn on the main unit and it should find and link with the wireless amp.
Dec 20, 2014 | Samsung Wireless Amplifier Swa-5000 For...
Cannot play blue ray movie on direct tv
not sure what youre really asking? you cant play a blue ray or dvd threw your direct tv receiver. you can hook it up seperately and change your inputs on tv but not threw receiver.
Apr 04, 2012 | Insignia NS-BRDVD Blu-Ray Player
SAMSUNG SWA5000 Wireless Receiver Module stopped working **help help**
HiI have the same problem, have you found the solution?
cheers,
Dec 29, 2011 | Samsung SWA5000 Wireless Receiver
Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
May 03, 2009 | NexxTech DP3222 DVD Player
Just connected the SWA-4000 wireless amplified to my samsung ht-z310 - the readout on the display is "Rear Chk" there is no sound from the rear speakers- any help is appreciated
swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
Dec 13, 2008 | Samsung SWA-4000
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Nov 08, 2008 | Samsung SWA-4000
Problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
Oct 19, 2008 | Samsung SWA-4000
Should link up.
Oct 06, 2008 | Samsung SWA-4000
Can't power on
try unplugging the dvd player then plug it back in as this treats it like a reset.
Mar 13, 2008 | Aspire Digital AD-8091 DVD Recorder
Samsung SWA-4000 Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
