Toshiba Manual 58L7300 - Office Equipment & Supplies
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
Tip
Toshiba 55HX70 Manual Download
Download Toshiba 55HX70 Projection Television Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 55HX70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55HX70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 55HX70 Projection Television instructions.
I hope that helps.
_______________________________________________
Toshiba 55HX70 Service Manual Download
on May 10, 2010 | Toshiba 55HX70 55" Rear Projection...
Tip
Toshiba 61HX70 Service Manual Download
Download Toshiba 61HX70 Projection Television Service Manual
Have you misplaced your Toshiba 61HX70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61HX70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 61HX70 Projection Television troubleshooting & repair instructions.
I hope that helps.
Toshiba 61HX70 Manual Download
on May 10, 2010 | Toshiba 61HX70 61" Rear Projection...
Tip
Download Toshiba 61HX70 Projection Television Manual
Have you misplaced your Toshiba 61HX70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61HX70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61HX70 Projection Television instructions.
I hope that helps.
Tip
Toshiba 61H70 Service Manual Download
Download Toshiba 61H70 Projection Television Service Manual
Have you misplaced your Toshiba 61H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
Toshiba 61H70 Manual Download
on May 10, 2010 | Toshiba 61H70 61" Rear Projection...
Tip
Download Toshiba 61H70 Projection Television Manual
Have you misplaced your Toshiba 61H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television instructions.
I hope that helps.
Tip
Toshiba 43H70 Service Manual Download
Download Toshiba 43H70 Projection Television Service Manual
Have you misplaced your Toshiba 43H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 43H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 43H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
Toshiba 43H70 Manual Download
on May 10, 2010 | Toshiba 43H70 43" Rear Projection...
Tip
Download Toshiba 43H70 Projection Television Manual
Have you misplaced your Toshiba 43H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 43H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 43H70 Projection Television instructions.
I hope that helps.
Tip
Toshiba 55H70 Service Manual Download
Download Toshiba 55H70 Projection Television Service Manual
Have you misplaced your Toshiba 55H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 55H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
Toshiba 55H70 Manual Download
on May 10, 2010 | Toshiba 55H70 55" Rear Projection...
Tip
Download Toshiba 55H70 Projection Television Manual
Have you misplaced your Toshiba 55H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 55H70 Projection Television instructions.
I hope that helps.
143 people viewed this question
jasbo
jasbo
