Question about Samsung UN55C9000 55 in. 3D LCD TV
Black horizontal lines
Thick horizontal lines every 1/4 inch on right side that disappear approximately 2/3 of the way to the left of screen.
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
  • 1153 Answers
SOURCE: Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
Posted on Mar 10, 2008
SOURCE: got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Posted on Feb 06, 2009
romsky79
  • 822 Answers
SOURCE: 3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
Posted on May 25, 2009
vinnyq
  • 157 Answers
SOURCE: 2 BIG THICK LINES ON LEFT HAND SIDE OF THE SCREEN
If the lines are vertical and go from one side of the TV to the other, it is most likely the scalar boards. There could be a loose connection from the PDP module (plasma panel) and the scalar boards. Otherwise, the scalar boards need to be replaced.
If the lines are horizontal, then the same thing as above except for the y-drives instead of the scalar boards.
Posted on Oct 06, 2009
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Right edge fades to black (Approx 2")
ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
Sep 28, 2007 | Toshiba 44NHM84 44" TV
How do I resolve a problem with a black vertical line that's appeared approx. 2 inches from the left side of the TV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 27, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
On left hand side of page horizontal line
You might have touched the main charger cleaner a green part above the waste toner container. just push it inside and try to copy and print
May 11, 2010 | Copystar Office Equipment & Supplies
LARGE HORIZONTAL BLACK LINE- PSC 1610 PRINTER COPIES
NO, I DID NOT GET IT FIXED. YOU TOLD ME TO SCAN SOMETHING TO THE PC, WHICH I DID. SENT PAGE TO MICROSOFT WORD AND THE BLACK LINE WAS STILL THERE. I BELIEVE MY SOLUTION IS TO JUNK THIS THING AND BUY ANOTHER.
Jan 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
HORIZONTAL LINE THROUGH PICTURE
Defective LCD panel. I hope it is under warranty, otherwise you'll have to live with it or buy a new set, as the LCD panel costs almost as much as the TV itself.
May 20, 2009 | Sharp Televison & Video
Samsung UN55C9000 55 in. 3D LCD TV Logo
Jerry Greenberg
Jerry Greenberg
