Question about Whirlpool LTE5243DQ Combination Washer/Electric Dryer
Dryer door switch on whirlpool washer/dryer lte5243dq3
3 Suggested Answers
  • 7 Answers
SOURCE: whirpool twin washer & dryer lte5243dq3 drum off center
The ltw5243dq3 is a top loading washer with the dryer stacked on top. In order to remove things
1. One the angled piece of metal that is between the dryer and the washer there will be two screws. Remove them.
2. Next open the washer lid. There will be two screws on the right side. Remove those.
3. Close the lid. There are two final screws that hold the top part of the washer in place. You can't see them directly from the front so you might need a mirror or access to the back side of your unit.
4. Slide the top of the washer forward about 1 inch. List it up about 1inch and you will see that some wires are attached. Disconnect these wires so you can take the top off entirely.
5. To remove the front panel there are two screws. One on the left and one on the right. If you look down inside in the washer you will see them.
6. Slide the front panel upwards and then you will be able to remove it.
You should now be able to see inside your washer and it should look like the attached picture.
hope that helped,
mishkin
Posted on Apr 03, 2009
richroth
  • 9472 Answers
SOURCE: whirlpool washer knob won't come off
What is the model number of your unit?
See if this service manual will help you.
Posted on Nov 25, 2012
I have to replace the timer knob on my whirlpool LTE5243DQ3 combination washer and dryer,but I cannot remove the old one
oh boy these are varied in the way to remove them, but usually under the knob is a pin, or screw and in some cases a u shaped plastic pc that locks timer to knob shaft? in some cases on the back side the shaft has to be pulled up then remove the locking pin or u shape piece to release it and wow it comes off
Aug 19, 2014 | Whirlpool 27 " White Combination Washer...
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
My Thin Twin stackable washer & dryer Model # LTE5243DQ3 is having problems w/the washer spin cycle. I'm thinking I may just need a new timer because it goes through all the cycles except the spin...
Before wasting money on a timer that wont be returnable once it is removed from the packaging please respond to me and tell me does the washer do everything including draining, and the only thing it will do not do is spin
or will it wash but not drain and spin
their are 2 posibilities based on your response and neither is the timer
Thanks,
Gene
so ya know i have beena appliance repair technician for over 30 years
Jul 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
Dryer model # lte5243dq3 take to long to dry clothes
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Apr 17, 2011 | Whirlpool LTE5243D Top Load Stacked...
No heat in our Whirlpool Dryer Model LTE5243DQ3. Tested both fuses and all the wires have power. Still there is no heat. The parts tested were 3398128 and 3404154. Are we missing somthing?
There is what's called a high limit in dryers. It protects the unit in case of over heating. It usually is small, has 2 wires connected to it. Check continuity. Or' check your heating element for breakage, or continuity.
Dec 23, 2009 | Whirlpool LTE5243D Top Load Stacked...
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
Whirpool twin washer & dryer lte5243dq3 drum off center
hope that helped,
mishkin
Mar 29, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool LTE5243DQ Combination Washer/Electric Dryer Logo
111 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
