Question about Mitsubishi WD-82738 DLP TV
Mitsubishi tv wd-82738 no power
T.v tries to power up but then shuts down,red light appears
  • 1030 Answers
SOURCE: mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Posted on Dec 13, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
SOURCE: Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
Posted on May 15, 2009
sethdileswar
  • 253 Answers
SOURCE: Mitsu WD-62725 green light blinking continuously.
pls check remote aur repair smps power supply of tv
Posted on Apr 05, 2010
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
What is wrong with Mitsubishi tv Model WD:82738? I just replaced the lamp and it is making a sound like a bearing rubbing and the picture is flickering.
It sounds like your color wheel is going out. Here is the part#. If you do not feel cofortable with this type of repair, please have a servicer do it for you. Good luck to you.
May 23, 2016 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
My Mitsubishi WD-82738 dlp tv turns off after a minute
You have a power supply issue that needs to be addressed.
Mar 04, 2016 | Mitsubishi WD-82738 DLP TV
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
How do i change my fornat/resolution on my model wd-82738 tv
See page 6 (this is a display & basic explanation of your transmitter) of the owners manual http://mitsubishi-tv.com/asset/file/basic_owners_guide/738-838_BIB_v3.pdf
there is a format button on you remote transmitter. If you have other format issues it is probably your source & not the TV. You may have to change the source format in which case you will need that mfr. operating manual.
Apr 23, 2015 | Mitsubishi WD-82738 DLP TV
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
WD-82738 82-Inch six red blinks one yellow blink replaced chip to fix white pixels issue.
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Blinking code detail, and fault finding procedure to many brand TVs are given. Pull up older posts.
Nov 29, 2013 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
Most of these TV's have switched mode power supllies that run very hot. There is a likely chance that the capacitors have cooked (burst) on the PSU board. They are common capacitors. Open up the TV and with the mains electricity turned off, check the 'X' on top of the tubular capacitors. If they are bulging, rather than flat, then unsolder them and replace them.
I've repaired many of these sets because of this problem.
Nov 16, 2013 | Mitsubishi WD-82738 DLP TV
TV (wd-82738) shuts down unexpectedly and fast flashing green light comes on This occurs about once a week.
The tv flashing green light is on it have a word"LAMP"writing on the tv frame?Yes,than the tv projection lamp life it is ending.Tv unexpectedly shutdown the tv also have clicking noises sound too?That the board call the Ballast board is dying too,this board only job are only to ignite the projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp and might have also have to replaced the Ballast board too.
Apr 13, 2011 | Mitsubishi WD-82738 DLP TV
Shuts down automatically with red light
Push device and Menu in on the front panel together and hold for 8 seconds and see if the led blinks a two digit code. As it may be the lamp or quite possibly the Power PWB capacitors if it blink a 3 4 code.
Jul 16, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-82738 DLP TV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
