Question about Hilti 284228 UH 650 Universal 1/2" Hammer drill
Hammer drill 54-2714-2 wiring - Hilti 284228 UH 650 Universal 1/2" Hammer drill
Intermittent power
When drill working pull on mains cable. Not unheard of there being a break in the wiring around cable clamp of tool it can give similar results to what you describe. Have seen a drill work flat on bench, pick it up and it will not work and its just a break in the wireing.
Feb 23, 2014 | Dewalt Makita Hp2010n 6 Amp 34inch Hammer...
Wiring diagram of hammer drill model CD 50
I am an authorized DeWalt and Black and Decker dealer and that tool does not come up in my listings. If it is a non USA spec tool I can not access break downs or wiring diagrams for it.
Aug 18, 2012 | Black & Decker Drills
Ryobi hammer drill cuts out
This is usually indicative of a broken wire in the cord near the handle. Plug the tool in, hold the trigger on and pull the cord in different directions near the handle. If it cuts off & on, one or more of the wires in the cord are broken and it should be replaced.
Jul 18, 2012 | Drills
Wiring diagrams for makita hammer drills
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in the search box and the parts breakdown and owner's manual can be viewed or downloaded.
Jan 16, 2012 | Makita Drills
I have a very new GMC 1400 Watt hammer dril. when you press the trigger it will not work. I unscrewd the casing had a look couldnt see anything wrong, put it back together and it worked. Drilled a few...
YOU HAVE A LOOSE WIRE OR A BRUSH HANGING UP IN THE BRUSH HOLDER! LOOKE FOR WHERE THE WIRES GO INTO THE SWITCH, ALLOT OF TIMES THEY ARE LOOSE IN THERE, OR IF ITS LIKE THE BOSCH HAMMER DRILL, THE WHITE WIRES GOING INTO THE FIELD ARE FAMOUS FOR GETTING A LITTLE CORROSION ON THEM, OR COME A LITTLE LOOSE. INTERMITENT ELECTRICAL PROBLEMS ARE A NIGHTMARE, ALL IT TAKES IS A LITTLE SPEC OF DEBRIS BETWEEN THE BRUSHES AND THE COMMUTATOR AND THE TOOL WILL NOT RUN, MAKE SURE YOU BLOW IT OUT REALLY GOOD WHILE APART!
Jan 14, 2011 | GMC 65 Amp Hammer Drill
How can i get to the hammer cam, is it repairable?
http://www.us.hilti.com/fstore/holus/techlib/docs/tool_schematics/drilling/TE_7_C.pdf
Breakdown for the Double Insulated(2-wire) Drill
http://www.us.hilti.com/fstore/holus/techlib/docs/tool_schematics/drilling/TE_7_C_Grounded.pdf
Breakdown for the Grounded(3-wire) Drill
These should help you take the drill apart, and get to the piece you feel you need to replace.
Let me know if this helps.
Nov 29, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Oct 11, 2009 | Bosch Drills
Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Thanks.
Jul 28, 2009 | Drills
Hammer drills Power supply
There are cordless varieties of just about any type of hand drill, even the specialized hammer drill. These hammer drills work in the same manner as any of the core hammer drills or regular drills. Powered by a set of rechargeable batteries.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Hilti 284228 UH 650 Universal 1/2" Hammer drill Logo
56 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
