Question about Refrigerators
Dometic rm 2332
New cooling unit installed. New burner installed. Runs fine on ac power. Barely cool in freezer on gas power. Help!
  • 68 Answers
SOURCE: Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Posted on Mar 19, 2009
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
  • 127 Answers
SOURCE: I have dometic modle R M 2333. It will not cool
If the unit has a good flame and is staying lit throughout the cycle of the fridge, then you probably have a bad cooling unit. Does is cool ok on Electric? If so, then there is another problem. You may have rust build up in the flue that is not allowing the heat from the gas to work correctly. Try taking a screwdriver and small claw hammer. Remove the cover from the burner assembly and place the head of the screwdriver on the flue just above the burner. Tap the screwdriver lightly with the hammer and see if rust falls. If so, continue to do this until it stops. You then need to blow out the burner and try the fridge again.
Hope this helps,
Jeff
Posted on Jul 07, 2009
  • 9 Answers
SOURCE: dometic RM 2800
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
adnanbhatti
  • 1188 Answers
SOURCE: fridge barely cool freezer not freezing
I suggest first getting it checked. Maybe there is just a small leak which can be sealed and coolant refilled. If say the compressor is damaged or other major component then only the repair cost will dictate what to do next.
Refrigerators are not very complex and have relatively few parts. You will probably get satisfactory results from repairs.
Posted on Jul 29, 2009
Rm2652 barely is cool to the touch in the freezer and hardly nothing in fridge on electric and does nothing with LP gas...... Why?
If you can hear the coils "circulating" you have a leak in your cooling unit. If you can hear a boiling like sound from the cooling unit it is a tell tail sign that the unit is bad and needs replaced. If you take a look through the access vent on the rear of the fridge you will more then likely see the yellowish residue located around the burner area. This is the common spot for these models to leak. The unit can be easily replaced within just a hour or two with no specialized tools or previous knowledge required. I will attache a copy of our RM2652 installation instructions to view, Please contact Arcticold for your New replacement cooling unit with a Lifetime warranty. 1-888-782-6665 Our Online Store
or Visit ArctiCold Refrigeration We keep it cold
0ad626a4-1449-47d9-8bbf-2fa8d341ab27.jpg f025c046-0397-4b39-bb23-195d5af49be9.jpg 0a8ce3ce-0848-41b0-b50c-20f0b8f695aa.jpg f1777d50-69ba-43e6-9a3c-00e81e4db981.jpg cfd97b8a-7816-472c-98ae-d988ab6f12b2.jpg b8312661-bb6d-437c-b166-2d1d837997fc.jpg
Our install video for that model is
Aug 14, 2014 | Dometic RM2652 Refrigerator
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Dometic RM 3662 not working on gas or AC power. I've changed the heat element, I can see the flame of the burner. What's going on that the unit won't cool off. Tried gas for 5+ hours and the fridge seemed...
When running on Electric insure that the rear coils of the cooling unit are getting warm. If the refrigerator is level and the coils are warm and the refrigerator does not cool then you more then likely will require a replacement cooling unit. I have attached a small video that may help with the diagnoses. You can also give us a call toll free 1-888-782-6665 ArctiCold Refrigeration We keep it cold
Aug 27, 2013 | Dometic Refrigerators
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
Dometic RM 2800 Refrigerator will not cool. freezer is some cool. this is on LP gas
Jul 12, 2009 | Dometic Refrigerators
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
My 1995 Dometic 2611 runs OK all day but not at night
Yes more than likely the cooling unit is going bad. If your boiler tube is hot the cooling unit is no good. Your frig is 13 years old, it has reached its life span and beyond. A cooling unit or a new frig can be purchased from www.coachtech.info. Just send them an e-mail.
Feb 28, 2009 | Dometic RGE400 Top Freezer Refrigerator
Jan 11, 2009 | Dometic RM2852 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
