Question about Garden
Homelite hlt25cs How to put throttle back on
2 Suggested Answers
SOURCE: homelite hlt25cs centre of line
I had the same problem, the black knob on the bottom just slips round not unscrewing the bolt inside. I had to lever the knob off and then undo the bolt with a spanner. The re-threading instructions are in this manual : http://manuals.homelite.com/documents/2588
Posted on Dec 27, 2011
Carb settings for Homelite weedeater ST-275
Set both the H and L for 1 1/2 turn out from bottom, start and adj. The H for max rpm for full throttle, now set the low for good idle and very little or no hesitation when opening throttle. Now set H for max rpm again and then back off until you get more of rumble at full throttle.
May 31, 2017 | Homelite Garden
Homelite Super ez auto starts, but when given throttle, it boggs down. carb is at correct settings. It idles well, but no throttle, but in a blue moon it wants to kick in for a second.
Have you changed the filter in the tank(if applicable). Also could need a carb rebuild kit. Sound like the diaprgams in the carb could be keeping up at a idle but not putting out enough fuel when you open up the throttle.
Sep 08, 2013 | Homelite Garden
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
Homelite hlt25cs centre of line spool stuck on whipper snipper
Aug 07, 2011 | Garden
Working on greasing up my Homelite UT 20760 grass trimmer. Took the throttle assembly part and having difficulty putting it back together. Can't find any diagrams and which hole to attach to on the...
Were you greasing the flex drive cable? That is really the only part requiring it unless you have a gear drive on the string head. Attatch the throttle cable onto the throttle plate hole which gives you the least amount of slack with the trigger off. That way, throttle response will be instant.You don't want but a little slack in that cable.
Jul 19, 2011 | Homelite Mighty Lite Lawn Trimmer
On homelite string trimmer prime bulb does not pop back up
this is an indication that there a gas blockage in either the fuel lines or the carborator. try taking fuel lines off of gas tank, which might require you to take off any protective coverings(just remember how they came off to put them back on the same way) .blow on each line separatly while holding throttle open on carborator. hopefully you'll feel the blockage being freed up. in any case put the lines back on and see if that does the trick. good luck!
Jun 30, 2010 | Homelite Garden
I can not find a throttle cable for the Homelite UT08514
HM 270021002 throttle cable $2.60 + 10.50 shipping. Can have it to you in 2 business days. Would you like an invoice? if so, reply to rwvanlueebay@att.net
Nov 08, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite saw runs wide open(homelite ut10520)
There is a recall on the UT models, all you have to do is call the costumer service center for homelite. they will give you a number for the closest warrenty center that will adjust you throttle cable free of charge. I went through two UT 10520's before i started researching the problem.
Feb 02, 2009 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
