Question about Vehicle Parts & Accessories
M103 wont shift into 2nd until 4k rpms
M103 motor. 92 w124. just adjusted throttle cable and fixed a vacuum leak. it wasnt doing this prior to adjustment. once into second, transmission shifts smoothly until coming to a complete stop again.
  • 787 Answers
I do not know what an M103 or a 92 w124 is. I can tell you however that if it's an auto transmission that the shift linkage, kick down plate and throttle assembly all work together so more than likely when you adjusted the throttle you messed up the shift points for the transmission.
Posted on Nov 21, 2013
My 99 dodge dakota sport is having a hard time shifting.
there is a vacuum hose that runs from the inlet manifold down to the gear actuator on the transmission
that unit uses the manifold ( throttle setting) vacuum to change the ratios appropriate to engine load
the hose is prone to cracking , breaking or falling off
May 30, 2017 | 1999 Dodge Durango
2002 sl2 rpms very slow to drop when shifting manual transmission
Okay, check the TPS you installed for proper meshing of the components. Disconnect the throttle cable and feel action of spring for binding. Check throttle plate for carbon and dirt buildup, clean.
Now some TPS units have a slot on one end. This can correct the jump in RPM. Just slide the unit either way while the engine is running and see if it speeds up or decreases the idle position. Then tighten the mounts. There are some other adjustments possible but check for a bad intake leak.
This can be done with the engine running and using a spray bottle of water. Mist the seams of the intake gasket and around vacuum lines. Any change in RPM or stalling will prove there is a leak and allow you to fix it.
It is kinda simple. A air leak is like opening the throttle to let more air in. The engine will run faster. Correct the leak and the idle should be reduced.
Sep 30, 2012 | 2002 Saturn Sl
How do i fix my high idle problem on jeep wrangler
a quick fix is to look under the hood, look for where the intake meets the throttle body, you will see a bolt which can be adjusted. When you start to screw it out, your idle will decrease...
Apr 24, 2010 | 1998 Jeep Wrangler
Transmission does not shift out of 1st gear automatically. must get off gas for rpms to drop and then it will shift to 2nd gear. no other shifting issues.
There is a vacuum line that is connected to a vacuum modulator on the transmission. The vacuum modulator looks like a tiny inline fuel filter on the right rear of the transmission. Remove the vacuum line from the modulator, if transmission fluid spills out when the rubber hose is removed the modulator is punctured. The engine will **** your transmission fluid through the vacuum line and into the intake system and burn it through combustion. If the modulator is punctured you must have it replaced.
Nov 29, 2009 | 1992 Ford Explorer
2001 Isuzu Rodeo Check Engine Light flashes when accelerating.
I would change the trans flter, trans fluid, and have the linkage on the trans adjusted.
Jul 21, 2009 | 2001 Isuzu Rodeo
92 FORD T-BIRD 5.0L SPORT TRANSMISSION problem
3RD GEAR IS THE DIRECT CLUTCHES . WHEN THE GROMMET BROKE YOU LOST LINE PRESSURE IN THE TRANSMISSION RESULTING IN BURNING THE CLUTCHES .THE ONLY FIX IS TO REBUILD OR REPLACE TRANNY.BAD DESIGN BY FORD .YOU CAN FIND A BRONZE ONE AFTERMARKET
May 06, 2009 | 1992 Ford Thunderbird
92 Dakota, trans doesn't slip, but stays in first a long time.
Possible throttle valve adjustment. Very critical. Cable is adjusted at throttle body. Too loose or too tight will have adverse effects. Recommend trans specialist perform adjustments
Mar 31, 2009 | 1993 Dodge Dakota
''88 chevy K2500 won't shift past 2nd gear
Tha vacuum modulator will not keep the truck from shifting,it only helps with sift quallity.it sound like you have some internal problems and will need to take it to a transmission shop
Jan 02, 2009 | 1988 Chevrolet K2500
Transmission wont shift
check the kickdown/throttle valve cable. It may be bound up and stuck in the maximum position giving you extremely late shifts.
There ISN"T any modulators or vac lines on any Chrysler automatics
Nov 08, 2008 | 1993 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
119 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
