Question about Cuckoo IH Rice Cooker CRP-HS0657F
Chukoo ih power doesn't come on - Cuckoo IH Rice Cooker CRP-HS0657F
I DONT NO THE IH POWER SUPPLY
The IH power supply is located below the operational panel behind the front cover below the op panel,
Sep 23, 2015 | Konica Minolta Bizhub C552 Copier
C41 lock thish machine
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine. When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Feb 08, 2013 | Toshiba e-Studio163 Copier
Toshiba 280 copier c440
press
0 + 8 --> power on
400 --> start --> 0 --> interrupt
Jan 09, 2013 | Toshiba E Studio 230 280 Copier
Error c472
[C471/472/473/474/475] indicates IH power voltage abnormality or IH initial abnormality
Clear the status counter (08-400) to "0". If still occur again, u need to check followings:
1. Check the AC input voltage
2. Check the thermostat
3. Check the IH control board
- Check if the AC input connector on the IH control board, the LGC I/F connectors CN455 is dis-connected?
- Check if the fuse on the IH control board has blown.
- Replace the IH control board.
4. Check the LGC board
Jun 17, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
Error code c447
Fuser error...
Clear the message... 08-400 "0"
If occur again, u need to check the fuser probable, such as themistor, IH board, connectors and etc...
Apr 05, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
IR 6570 Error occurs E804-002
This is an error for the DC power supply fan - there is an IH power supply cooling fan error. The book I have doesn't give the 002 part of the error but check that
Jun 21, 2011 | Canon imageRUNNER 5570 Copier
Call for service C10 C440
turn off the machine
push " 0 + 8 " + turn power on at the same time
type 400 + start
type 0 + enter
restart the machine
Jun 09, 2011 | Toshiba E-STUDIO 450 Copier
C440
try to reset that error by pressing the ff first turn the machine before turn it on press 0&8 simultaniously then turn it on the power switch do not removed pressing 0 & 8 after 5 seconds after you turn on the machine unhold the them then enter 400 then start then if there is a number 1 appears on display just select 0 then press start the turn off & on the power switch
Nov 21, 2010 | Toshiba e-STUDIO 352 Black and White...
I got a C440 error code sub code "7" with Toshiba E-Studio 352 copier. I tried to reset using 0/8- 400 but still the error code appears. what is the possible defective parts?
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
CN455/456).
please vote me.
Thanks
Best Regards,
Jun 08, 2010 | Toshiba Office Equipment & Supplies
Error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Dec 04, 2008 | Toshiba Estudio 200L Copier
Cuckoo IH Rice Cooker CRP-HS0657F Logo
Top Cuckoo Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Cuckoo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
