Question about HP PSC 2355 All-In-One InkJet Printer
Printing Error I recently received an error message that I didn't write down. I turned the printer off and then back on. After going through this procedure, I now get an error message indicating that I have the wrong type of ink cartridge (which I don't). I have been using the same ink cartridge for months without any issues. marc
    Novelist:
    Scholar:
  • 167 Answers
Try changing the ink cartridges.
This may have happened due to low ink levels. Also try reinstalling the printer driver.
If the print cartridges are damaged this problem will pop up. Even static electricity in human hand could damage the print cartridges.
Posted on Oct 19, 2007
SOURCE:
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
I received a new printer today, I installed the software and ready to test print page. I get error message that the carriage is stalled. I found a procedure on HP web site that to fix problem, but it...
The printer may be faulty. I suggest you return it to the supplier to have it fixed or replaced under warranty. If you try to fix it yourself you may void your warranty.
Jul 14, 2011 | HP H470 InkJet Photo Printer
When I turn on my brother mfc 8440 I received this message in the screen : Error 6A
To clear the error, the procedure is as follows:
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
This should clear the error.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 05, 2011 | Office Equipment & Supplies
Ink system failure Oxc19a0013 HP Photosmart B110
Check all of your cartridges to ensure that all of the protective tape has been removed. If you still receive the message after the check then power down your printer and remove the power cord from the back of the printer. Remove all of the ink cartridges from the printer. Wait 2 minutes, then plug the AC cord back into the printer. Turn the printer back on. Once the printer goes through it's power on self test it will ask you to insert the print cartridges. Go ahead and do so. If the error message does not display itself then you are okay to go ahead and use the printer. However, if you still receive the error display then you will have to have the printer serviced. Unless you have the tools, experience, and a copy of the service manual for your printer, it is best to have your local HP repair center take a look at the printer. The code signifies an ink system error, but there are a number of reason that can cause the error to display.
Mar 13, 2011 | Office Equipment & Supplies
Error 6502
Dear Asker
how would i know this error is for which printer so i am assuming it's cannon.
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Feb 28, 2011 | Office Equipment & Supplies
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
I get error meesage 1102 on my Dell 944 printer. it's telling me cartidge error or incorrect cartridge. i have used only Dell cartridges and have not changed recently. the cartridges are not empty. can...
Turn off the printer and unplug the power cord for about a minute. This should reset the error codes. If you still receive the same code when you go to print, open the case and the cartridges should move to the center to be replaced. Take each cartridge out and make sure there is nothing that is covering the sensors or physically wrong with them. Put the cartriges back in and make sure they are "seated" properly. Test to see if you still receive the error message.
If you still experience the error message and the cartridges are old or less than 50% ink, there might be an issue with the cartridge's internal sensor. You can find out more information on the internal sensor's HERE
Dec 14, 2009 | Dell Office Equipment & Supplies
Canon iPF8100 Error message E602 401b
Our Canon iPF810 recently had the error message "E602-401B" while it was still under warranty. At that time the hard drive was replaced, but it didn't solve the problem so the original hard drive was put back in and the firmware was updated and the machine worked fine for about 9 months.
We got the same message again and the machine was not under warranty so repair would be quite expensive ($1000.00 flat rate fee). After making calls to repair places, one place gave me some valuable information.
They suggested that if I could get into "Service Mode", select "System Setup" and then "Erase HDD". They said the hard drive probably needed to be defragmented. Amazingly enough, it worked! The hardest part was figuring out how to get into "Service Mode".
With the machine switchoff OFF, hold down the "sheet or roll feed button" and the "information button". Keep these pressed and switch the machine on, keeping the buttons pressed until you see an "S" in the top right-hand corner of the display, then let go of the buttons. You should now be in "Service Mode". Then go to "System Setup" and then "Erase HDD". Your machine should work after following these procedures.
It seems like the plotter stores every plot in its memory. After a period of time, the plotter's memory gets filled up and the "E602-401B" error message occurs. To prevent this from happening, periodically erase all the old plots. The procedure for doing this is as follows:
On the plotter "Main Menu" choose: "Job Management", "Stored Job", "Common Box", "Job List". Then delete each drawing/plot.
Nov 27, 2009 | Canon imagePROGRAF® iPF8100 InkJet Printer
HP photosmart C5180 all in one: Ink system has failed
Here's a link to a procedure that one individual used to fix the same problem with his printer. I can't guarantee this will work in your particular case.
HP C5180 All-In-One Printer HARD RESET:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn’t power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Now you can release the buttons and simply power it back on. (I held my breath, but that’s not required.)
    • I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
reference: http://www.mlnarik.com/jewel/2009/05/21/how-i-fixed-my-hp-c5180-printer/
Aug 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
On Oki C5600 printer with error message " Order k drum" and does not let me print. Can any one help how to reset and clear this message?
Try this procedure, don't know if it will work on your models.
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Apr 12, 2009 | OKI C5500n Printer
HP PSC 2355 All-In-One InkJet Printer Logo
96 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
