Samsung dimond wf8602ngw wont fast spin
2 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: WF8602NGW WASHING MACHINE WONT SPIN AND HEI
Here is the main ONLINE SUPPORT page for your model:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SIA00201&prd_ia_cd=&prd_mdl_cd=WF8602NGW/XEU&prd_mdl_name=WF8602NGW
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://downloadcenter.samsung.com/content/UM/200901/20090122161637390/WF8604NG-02607A_ENXEU.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
  • HE1 Error code is the result of a possible problem with the WATER HEATING SYSTEM.
    It gets displayed when the water appears to heat up too quickly or too slowly.
    It may just be a temporary sensor glitch, in which case it can be cleared by turning the power OFF, or even unplugging the power cord temporarily.
    If the error condition persists, then your machine may have a faulty heating element which will need servicing.
  • I truly hope that was helpful to you.
    Good luck and take care.
    Joe.
    Posted on Oct 10, 2011
    Detrola cd player spins too fast
    Did you undo any leads when you changed the belt, are they in the correct position, it's spinning fast because it can't focus.
    Aug 29, 2014 | Televison & Video
    Why wont it spin fast
    Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
    Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
    How to replace Beko Washing Machine Motor Carbon Brushes
    Aug 08, 2014 | Beko WME7247W Washing Machine
    WF8602NGW WASHING MACHINE WONT SPIN AND HEI SHOWING?
    Joe.
    Oct 10, 2011 | Washing Machines
    SUMSUNG DIAMOND 6.0KG WF8602NGW IS is showing HEI pls help ! as i missed place the manual instructions.
    First of all, thank you very much for choosing FIXYA today for your technical support needs.
    Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
    Be sure to click on the small blue COMMENT button located just above or below the text of this solution to leave any additional comments for me regarding this particular issue.
    Joe.
    We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
    We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
    Nov 14, 2010 | Samsung Washing Machines
    Maytag Performa agitates, but wont spin corectly.
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Jun 07, 2010 | Washing Machines
    My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
    Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
    Sep 16, 2009 | Washing Machines
    HTC Touch Dimond displays Roaming symbol E beside Signal strength
    yea i also have the same problem even though i have my data switched off nd no gps etc. wont i b charged for the e symbol meaning it uses data even thou i have data switched off? this is really weird someone please help us out. thanks
    Jun 15, 2009 | HTC Touch P3450 Smartphone
    Have a ryobi rlt 30 cd and the spool wont spin fast enough
    hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
    Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
    Washing Machines Logo
    Top Washing Machines Experts
