Question about Timex T53722 Ironman Data Link USB Watch
Need to order replacement strap for Timex T53722 Ironman Data Link usb
SOURCE: I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
Posted on Jan 25, 2008
SOURCE: Timex 1440 Sport watch needs a new strap
Hi I have a 1440 sport watch , somehow I got it into 24 hr mode vs regular time. Can't seem to figure outhow to get it out of this.....HELP :)
Posted on Mar 23, 2008
escapement
  • 2334 Answers
SOURCE: timex ironman triathlon - need directions to adjust time for day
Follow this link and download usars manual for your watch:
http://assets.timex.com/manuals/?timexBrand=core
Use ZOOM tool as the writings are tiny.
Do not forget to rate, please.
Posted on Mar 09, 2009
VOTIT
  • 2071 Answers
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Posted on Jun 08, 2009
  • 65 Answers
SOURCE: after replacing a battery in a timex ironman with
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Posted on Jul 27, 2009
How do I get service/repairs for the DISCONTINUED Timex T53722?
You might try going to this Timex repair link and ask them for a list of authorized Timex repair shops in your area. Or you could send it back to them.
http://www.timex.com/info/repairs
Mar 12, 2014 | Timex T53722 Ironman Data Link USB Watch
I need a replacement band for a timex data link 53722. This is a unique shaped resin band.
one thing i know when it comes to timex band, you have to place an order on it's authorize retailer. because that kind of watch didn't have anywhere but timex only. i hope i had been helped you.
Jul 22, 2011 | Timex Advanced Data Link 53722 Wrist Watch
Strap broken on timex heart rate monitor watch 30 lap ironman triathlon need a replacement
Hi, Almost any large dealer like Wal-Mart, Sears, or Target will have Timex replacement straps and bands for most popular watches and monitors. Sometimes a local Authorized Dealer will have specialized products that the department stores don't even carry without ordering.
I have had good luck with Wal-Mart on watch accessories. I've also ordered straight from Timex in Little Rock, Arkansas, ph. 1-800-448-4639, but it usually takes more time for just parts.
Thanks, Bill
Sep 06, 2010 | Timex Ironman T59761 Midsize 30 Lap...
On my Timex T53722 the bottom of the display is cut off and the Contact mode is getting erratic. It has a new battery.
mcdevito75 here, If you changed the battery yourself, you"ll have to go back into the watch to make sure the buttons are presssing fully, and on the correct spot on the quartz movement, some times these button contacts get mis-aligned due to moveing the movement while replaceing the battery, you"ll also have to check the battery contact in the watch also, make sure the battery is being held fairly tight, the battery could have gotton loose. If you had the shop replace the battery, return to the shop for adjustments.
Jul 18, 2010 | Timex Advanced Data Link 53722 Wrist Watch
Replacement watch band web site?
mcdevito75 here, Timex.com should help. Also look for a small watch repair shop in your area for a replacement strap, and they may even have faster accesss to Timex.
Jun 27, 2010 | Timex Sports Ironman Triathlon 100-Lap...
After replacing a battery in a timex ironman with data link, they tell you to short the ac pad and the vss pad. Were are those points located?
Jul 26, 2009 | Timex IRONMAN Triathlon Data Link T53722...
Ironman Triathlon Sleek Ladies Watch Band Rubber Strap Discolors
Unfortunately there is no way to get rid of that discolouring.This is due to sunrays+swetting+chemical composite of strap material. Would be too long to explain how it works, so, here is the link where you can order the new strap:
http://www.timex.com/gp/node/n/256542011/ref=sc_bb_c_11_251377011_15/190-2521384-6105829?ie=UTF8&node=256542011&no=251377011&timexBrand=core&me=A1S5XB33AHYRMX&clicked=center-1115
Rate me, please.
Jul 20, 2009 | Ironman Triathlon T59211
Timex T53722 Ironman Data Link USB Watch Logo
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
