Question about Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
Change password on wireless cable modem gateway
I need to change the password on my new SBG6580-G228
How do I change access password
http://arris.force.com/consumers/articles/General_FAQs/SBG6580-Admin-Login-Setup
Oct 24, 2015 | Arris SURFboard SBG6580 eXtreme Wireless...
I have a SBG6580. I am trying to enter the security key but cannot find it on the back of the router...please help
I shall have to assume you in a 'Factory Reset' situation, where you have not signed into the modem, and changed username/password defaults, (new unit, fresh out of the box).
Do not connect to the cable company yet. First, secure the modem.....
From the User Manual, page 9..... You do have a User Manual?
1. Open a browser window, after connecting your computer.
Use a 'wired' connection. Never change security settings, using Wi-Fi connection.....
2. Type in the IP address for the modem 192.168.0.1 in the URL address. That should take you to the modem's password change window.
3. Type in the default Username: admin.
4. Type in the default Password: motorola.
5. Type in your new username in the Password Change Username field.
6. Type in your new password in the New Password field.
7. Re-enter your new password
8. Re-type your new username in the Current Username Password field.
9. Click Apply.
10. Connect the modem to the cable company. You should shortly be able to go online, after the modem has synchronized to the cable company. That usually takes about a minute.
Your question asks for the 'security key'. That generally refers to the Wi-Fi settings. If that is the case, go to the 192.168.0.1 address, sign-in, and click on Wireless. Follow the obvious directions.... Or, post here again....
Feb 12, 2015 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How do I change the "Pass code" on my wireless Motorola surfboard modem ???
If you mean the wireless pass code or Passphrase you need to log onto your modems web page which normally sits at IP address: 192.168.100.1. In the wireless section there is the pass code update field.
Dec 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How to change password
You have to Iogin to change it. If you forgot you may have to reset first.
If you have further questions contact ARRIS
Mark
Motorola Support
Aug 17, 2014 | Arris SURFboard SBG6580 eXtreme Wireless...
How do you change your wifi password
Follow the steps one by one:
1.Open a browser window.
2.Type in the IP address for the modem 192.168.0.1.
3.Type in the default Username: admin.
4.Type in the default Password: motorola.
5.Type in your new username in the Password Change Username field.
6.Type in your new password in the New Password field.
7.Re-enter your new password.
8.Retype your new username in the Current Username Password field.
9.Click Apply.
10.Write down your new password and default password for future reference.
Jan 21, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I cannot sign onto my motorola surfboard router site, no user names or passwords work. please help. my other laptop connects to wifi network fiine, but other one keeps asking for pin or security...
Connect to it directly using a LAN cat 5 cable, not wireless.
Log in as admin to the router, and change the wireless password to something new.
Disconnect the cable then try connecting from each laptop by wireless, when it prompts for password enter the new password.
Dec 14, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I have a Motorola SURFboard Gateway SBG6580 modem. I want to use the wireless for my DS lite but it says that I need an WEP key, but I don't know how to enable it. Help!
Your wireless is set up with a password. You need to get that password before you can connect any more devices. From a computer that can connect to the internet go to 192.168.0.1. Then type admin for the username and motorola for the password. I believe from there you click Wireless then click Primary Network. You should see your wireless network name and password from there. I'm getting this from the modems manual here: http://www.midcocomm.com/_files/files/SBG6580.pdf
Oct 16, 2012 | Arris SURFboard® SB5101 Cable Modem
My iphone won't connect to my sbg6580 motorola surfboard
I had to restart my IPhone and now I cannot get my Motorola Modem to join onto my Iphone 4. I have the password and the serial # for the modem, but nothing will work. Please help
Oct 22, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
In need of a user manual for SBG6580 wireless router
The User Manuals for many of the Motorola modems and gateways are available from Motorola on their support site: http://www.motorola.com/Support/US-EN/Consumer-Support/Cable-Modems-and-Gateways . Select your model. On the next page, use the drop down menu to select User Manual in the Select A Topic drop-down menu. Then click Search. The direct link to the manual for the SBG6580 is http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG6580-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SURFboard_SBG6580_UserGuide.pdf . Note you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Oct 03, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
198 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
