Question about Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range
Keypad numbers not responding - Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range
Is there a way to lock keyboard while entering data
The Hidden Numeric Keypad on Your Laptop - For Dummies
www.dummies.com/.../the-hidden-numeric-keypad-on-your-laptop.html
The key to finding a laptop's numeric keypad is to use the Num Lock key. ... It's great for entering numbers or working a spreadsheet, but rather frustrating at other ...
windows 7 - Touchpad does not respond when I am holding ...
superuser.com/.../touchpad-does-not-respond-when-i-am-holding-key-o...
Mar 11, 2012 - Is there any way I could check what is wrong with my laptop? ... holding Space works fine for a normal click for entering the number in non-pencil mode. ... The mouse may work while pressing these keys. .... tour help blog chat data legal privacy policy work here advertising info mobile contact us feedback ...
Oct 27, 2015 | Computers & Internet
Control panel not responding to touch -- NOT in locked mode!
Sounds like you have a shorting membrane keypad, or there any be moisture or grease in the controls.
To remove the controller to check for grease and moisture, see the video here.
We would need your full model number from the tag in the cooking cavity or elsewhere on the oven to help you further, and our advice is free.
Please post a new help request with the full model number.
Jun 09, 2013 | GE Appliances 30" Trivection Built-in...
Sticky keypad
Your remote control need cleaning. You can do it by yourself. Check these links. Both of them have details about how to check and clean a remote control.
Feb 26, 2013 | Televison & Video
Samsung microwave has numbers on the display but keypad doesnt respond
It's probably a defective membrane keypad.
But without the full model number with suffix, we can;t give you an estimate and let you know your options.
Please post a new help request with the full model and symptoms.
Jul 02, 2011 | Samsung Microwave Ovens
Keypads will not respond. Either can't turn on or
Possible power supply problem--low voltage from master unit or dead batteries at each switch. Good luck!
Jul 25, 2010 | Lutron Electronic Low-Voltage...
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
My nokia 5300 keyboard are not working when i press them
  1. see the keypad membrane if it is have corossion cleaning alignment is a must or replace the flex
  2. pleace hitting the keypad driver on your phone it will not working change it.
Mar 18, 2009 | Nokia 5300 Grey Cellular Phone
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Craftsman keypad not responding
On the back of the motor unit near where all those white wires go you will find a button. Press and immediately release that and then walk over to your keypad and enter a four digit code of your choice and press enter. You should be good to go.
Jun 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Nov 18, 2007 | Microwave Ovens
Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range Logo
23 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
