Question about Fanner Masscool UHB-358B 3.5 External Hard Drive Enclosure - USB 2.0 to IDE or SATA IDE / EIDE, Serial ATA, USB 2.0 External Drive Case
The first time I tried to use the UHB-340U/PS, the hard drive could not be accessed - the message said it would have to be formatted: "D:/Not accessible - Volume does not contain a recognized file sy
My current computer is running Windows 8 OS.
UHB-330U doesn't work for Windows 7
Try shutting down your PC then start it back up again.. Sometimes it fixes the issue
Oct 31, 2017 | Fanner Masscool UHB-330U 3.5" Aluminum IDE...
Cannot format hard drive message appears : hard disk cannot be formated" all 20 hard drives on different computers giving me same problem
lets get all of the details first you say you cant access the hard drive then the message cant be formatted how are you trying to format the hard drives what procedure??? will need more imformation a hard drive must be formatted from a ""third party disc""
Apr 09, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard disc is curropt and needs to be repaired but does not repair and will not allow navigation
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
have you tried options available in this menu?
Dec 19, 2010 | Sony Playstation 3 (PS3) Console
Files not read & reading files format not occured only show the message box H:\ is not not accessible &not readable
1. may be ur flash drive corrupted, try formating using HP Usb format tool.. google it.
2. still ur not able to format, ur flash chip is damaged, find a new flash drive.,
VOTE for me.
Sep 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When I go to my computer the external drive is not there. I put 1 TB drive in the masscool case.
Not enough info. Make sure you plug it into the SAME usb port it was in before, or you may have to format the drive to work in the computer. USB does not work the same way as the sata or IDE drives.
Hope that helps.
Brock
Sep 16, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
I bumped against a chair
Try different slots. or on a other computer.
You could also try to open it a see if the internal drive moved out of place .. only try if you know what ur doing.
Feb 21, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
My cruzer micro 4gb flash needs compression but I get the message drive not formatted. How can I recover the data without formatting the flash drive since formatting will erase all of my data?
You can run a data recovery app on the drive and attempt to pull off any data still accessible. I recommend the GetDataBack Data Recovery apps from http://www.runtime.org . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Aug 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cannot Access USB
maybe your usb files are corrupted ,do the quick format
start--------right click on computer then click on manage then device drivers ,see if usb drive right click then format
Feb 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
Fanner Masscool UHB-358B 3.5 External Hard Drive Enclosure - USB 2.0 to IDE or SATA IDE / EIDE, Serial ATA, USB 2.0 External Drive Case Logo
50 people viewed this question
Top Fanner Computers & Internet Experts
baklogic
Level 1 Expert
Dilum Senarath
Dilum Senarath
Tracy
Are you a Fanner Computer and Internet Expert? Answer questions, earn points and help others
