Question about Westinghouse VR-3215 LCD TV
My 32in westinghouse flickers model#3215stops sometimes after bing on fog awhile
Tvwestinghouse vr3215 flickers stops sometimes when it on 4 awhile
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Westinghouse 32in. Model vr-3215 powers on but no sound no picture
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_20_2012_2_23_17_pm.jpg
Posted on Apr 20, 2012
Tv codes for Westinghouse rmt-17tv remote
Codes, if applicable, are stored in the remote.
Jul 07, 2016 | Westinghouse Televison & Video
Westinghouse VR3215 has sound but faint picture only seen using a flashlight.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 10, 2016 | Westinghouse Televison & Video
Screen flickers goes off sometimes after being on 4 awhile
CCFL lamps to back-light, and its inverter board should be checked. To get more details, http://electronicshelponline.blogspot.com/
Nov 16, 2013 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My 32in spectre tv flickers black, when I turn it on it sometimes stays on for a lil bit than starts blinking black again and when I play my Xbox I can still see what I'm doing on the screen but it...
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 23, 2012 | Televison & Video
I purchased 2 32in Westinghouse LCD HDTV and one 42in LED HDTV, BOTH the 32in LCD TV's have a volume that will not stay below max. Sometimes the volume bar will go away I can lower the volume, release the...
there may be some other source of intereference within the area that you have the tv placed try moving it to a different area and see if that works you are dealing with electron magnetic interference and infared waves
Jan 27, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
Power only works when it wants too
4 year old is about the right time for the power supply to fail. That will be the first place to look. Look for bad caps, over heated parts, etc.
See my basic troubleshooting guide and learn about bad caps, failed TV/MONITOR.
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Parts: try www.shopjimmy.com or Ebay
Jun 16, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
32in Westinghouse lcd / picture scrambled
my westinghouse has the exact same problem....i have noticed it will catch sometimes when the screen changes from one picture to another that is totally different and one right after another......
Jun 30, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
2002 Sebring -Odometer Lights Flicker then bing battery indicator
have the engine wire harness checked maybe a communication problem between modules.
Mar 27, 2009 | 2002 Chrysler Sebring
Bad picture
Sounds like a dry solder joint. When the tv is on for 4/5 mins the crack warms up and the gap spreads. When you turn off it cools and when it warms up it starts again.
Mar 18, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Rca tv will not power on
Check the horizontal output transistor. This may be shorted.
Mar 12, 2008 | RCA D52W19 52" Rear Projection Television
Westinghouse VR-3215 LCD TV Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
