Question about CIPHERLAB 1000 Handheld Barcode Scanner
How to do programming an Symbol LS2208 barcode scanner to read upc-a
2 Suggested Answers
SOURCE: Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Posted on Dec 12, 2008
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
How do I disregard the last character on a UPC bar code?
In general you can create an Advanced Data Programming Rule which will say: If you scan an UPC barcode, please send only the first 11 characters of the barcode.
There are programming barcodes in the manual for the scanner or you can use the 123Scan2 application provided at support.symbol.com to create the rule and print out an config sheet.
Aug 26, 2010 | Symbol LS2208 Handheld
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
Reversing first 2 digits of barcode
Attached are the programming barcodes for the LS2208 solve this problem. Print the attached file and scan the barcodes in order 1-10. This will only work on a LS2208. If you scan the Set Defaults barcode it will erase this programming rule.
there is a document you will need to scan to do this, if you want to send me an e-mail i will send you the document
kganoe@datexcorp.com
Mar 13, 2010 | Symbol LS2208 Handheld
Need to program scanner to read first 9 positions of a 17 position code128 barcode.... then add an "ENTER" stroke... then pause, then an F10 Key....
contact Symbol/Motorola Help desk at 1-800-653-5350. You will probably have to use the scan 123 utility, but the LS2208 may not have the capability
Aug 04, 2009 | Symbol LS2208-7AZK0100S Handheld
I have a symbol ls2208 that currently scans ISBN's, but wont scan upc's... how do I program it to do both?
It's really simple...go to Symbologies in the manual and 'ENABLE' UPC. If you don't have a manual, you can download one from: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=118628532&stateId=0%200%2012107128
You can alsocall the Symbol/Motorola HelpDesk at 1-800-653-5350 -- or you can call me at 1-866-306-7226 at qdata.
Cheers.
Billy Barcode
Aug 01, 2009 | Symbol LS2208
UPC TO ISBN CONVERSION
Scan the Enable Bookland EAN barcode from the LS2208 Product Reference Guide. It is on Adobe page 166 of 342 of this guide: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=113980484&stateId=1%200%20113974371
Jul 08, 2009 | Symbol LS2208 Handheld
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
Barcode scanner Symbol LS2208
I had the same problem with LS4278, you need to configurate your keyboard and scanner in the same regional and language options
Oct 20, 2008 | Symbol LS2208 Handheld
CIPHERLAB 1000 Handheld Barcode Scanner Logo
44 people viewed this question
Top CIPHERLAB Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
