Question about Whirlpool GU2400XTP Built-in Dishwasher
Door latch wont close on hotpoint dishwasher gcd4800l00ww
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
SOURCE: dishwasher door won't latch closed
Please tell me, did you find out what's wrong - because this has happened to me now. :(
Posted on Feb 25, 2010
  • 147 Answers
SOURCE: PRONGS WONT CATCH DOOR LATCH
You need whirlpool part number 3369457 and/or 3380854. Good luck.
Posted on Aug 28, 2012
My dishwasher runs but door is in locked position. it will now run with door open and the door wont close/lock
It sounds like your door latch got tripped into the closed position (even though your door is open). You MIGHT be able to use a screwdriver or some tool to be able to pull the latch lever back out to the open position, but it might also be necessary to take the door apart to get to the latch to be able to reset it. The real problem is that if it happened before, it will probably happen again. So the real solution is to replace the latch assembly.
May 31, 2015 | Jenn-Air 24 in. JDB2100AW Dishwasher
I am looking for service manual for my hotpoint dishwasher
google search make model number pdf and see what it comes up with...hope this helps if not ..send info here and ill try to find for you
Jan 02, 2015 | Hotpoint 24 in. FDW60 Free-standing...
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
The door wont shut properly
see this causes and use the common sense.God bless you
Latch on door wont alow door to close
that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 28, 2010 | Hotpoint Dishwashers
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Nov 18, 2009 | Hotpoint Dryers
Door won't close wont lock closed
Check the following if you have problem with your doors:
1)The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
2)Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3)The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4)If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 03, 2009 | Westinghouse Dishwashers
Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Jan 16, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
