NO SOUND FROM LG HT904TA HOME THEATRE SYSTEM
The DVD player works fine (as in I can play the dvd & it will play with sound from TV Speakers. But the 5 speakers & sub woofer will play sound for 1-2 secs & then go silent.
Doodad
  • 64 Answers
SOURCE: How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Posted on Jan 06, 2008
  • 7 Answers
SOURCE: Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Posted on Jan 27, 2008
TIPS72
  • 369 Answers
SOURCE: I have LG dvd player
Please check the menu and enable 5.1 surrond option on and the dvd player dose it support surround if yes also check that u have connected the correct colour cable in correct palces..
thanks
Posted on Jan 05, 2009
SOURCE: How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Posted on Jan 07, 2009
sticky92505
  • 77 Answers
SOURCE: TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Ryan
Posted on Feb 18, 2009
Toshiba tv has no sound but does with DVD player on, how do I regain sound for tv shows
is the dvd player a home theatre system?if yes,does the tv play sound via the dvd home theatre speakers when it is on?if yes then maybe you should double-check your audio port connections between the two for correct configurations
Jan 04, 2016 | Toshiba Televison & Video
I just bought a RCA rtd3131 home theater system. My husband trashed the manual and i can't get all the speakers to work when the cable is on. When the DVD is on all the speakers work but the sound is not...
If the cable tv has audio out jacks, or if you have a cable box with an optical audio cable, plug either the audio jacks into the RCA system or the optical audio cable, and the system should automatically simulate 5.1, through Dolby Pro Logic II. All speakers will not be at the same volume as they are simulating surround sound, not just playing the audio.
The TV will never have sound for the DVD as this system has no audio out puts. Realistically, most televisions have 10w speakers, and this system is 130w, so the TV speakers are useless in comparison.
Jun 28, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
I have LG dvd player connected to 5.1 home theatre system with 5 speakers......But only 2 speakers are working...theres no problem with home theatre, it works with all speakers when connectd to...
thanks
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
 Grubhead
Grubhead
