Question about Bradford White M250t6ds-1ncww 50 Gallon Electric Water Heater - Ta
Adjust temperature on Bradford white M250t6ds water heater
3 Suggested Answers
  • 5089 Answers
SOURCE: I need the basics for replacing a thermostat on a water heater...Bradford/White brand, model M250S6DS2 50 Gal, 4500 watt per element 240 voltage 50/60 hz. It keeps over heating even at lowest setting
Copy following link for replacing thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Suggest you might also want to test the elements while power is turned off, just in case the problem is element shorted to ground across metal tank to ground wire.
http://waterheatertimer.org/How-to-test-water-heater-element.html
At least you know the 240volt power to water heater and the circuit breaker are good.
Posted on Oct 01, 2012
  • 42 Answers
SOURCE: BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Posted on Dec 18, 2012
How do I light my hot water heater?
It is pretty easy - make sure gas valve is open, change control know to pilot. Press the ignitor a few times and once pilot lights up switch control to warm or hot position.
See instructions by downloading manual for MI-403SF6BN from this site
Bradford White Water Heaters Built to be the best
Sep 15, 2014 | Bradford White Bradford MI403S6FBN-337 40...
No hot water
First check the power make sure that is working if it is replace one or both elements. makes sure you match up the watts and voltage
Dec 13, 2013 | Bradford White M250t6ds-1ncww 50 Gallon...
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
Too much hot water, how to adjust water temperature
1) Copy following links:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) if you have electric water heater, and too much hot water, then thermostat may be bad, or element is shorted and needs replacement. Test elements first, and if they're ok then replace both thermostats.
Jan 22, 2013 | Bradford White M240s6ds-1ncww 40 Gallon...
How do you test a safety magnet on a robert shaw gas valve
Bradford White:
Bradford white service manuals:
http://www.bradfordwhite.com/documentation/residential/gas.asp
Depending on age of water heater, The air intake may need to be cleaned.
Remove combustion parts and use compressed air to clean arrestor screen located bottom of combustion chamber.
Get more fresh air to unit.
Check gas pressure.
Check color of flame, should be clear blue and not lazy yellow.
Install new gas control valve.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Aug 28, 2012 | Water Heaters
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
We have a bradford defender model # MI403S6FBN7. How do we reset it. lost manual
Water heaters are a huge field of knowledge. Problem is not 100% clear.
There is a resettable thermal switch on the combustion door. This switch is round and has two wires that come from gas control valve. Thermal switch trips when combustion parts have not been cleaned and they cause overheated condition, or sensor reads temperatures above 180, or thermal switch has gone bad, or gas control has gone bad.
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-8.jpg
Add a comment with more information for continued help.
1) Bradford White support:
http://www.bradfordwhite.com/supportserv.asp
2) Bradford white mi403s6fbn is 6-year-warranty 40 gallon tank-type gas water heater with Icon electronic gas valve, and atmospheric venting.
Older models have the dial-type Robert Shaw or White Rodgers gas valve.
Open following link to see age of Bradford White:
http://www.bradfordwhite.com/findaserial.asp
3) Bradford white has 'product manuals' and 'service manuals' on following link:
Product manuals have general information and advisories that people can read about water heaters.
Service manuals are for plumbers and technicians, and do-it-yourselfers for testing and repairing water heaters.
4) Typical manual for your product shows different gas valves, lighting instructions, and advisories, and troubleshoot checklist:
http://www.bradfordwhite.com/images/shared/pdfs/manuals/238-44219-00J.pdf
5) Add a comment with following information if you want specific help with servicing water heater.
What are you trying to reset on the water heater?
What are the symptoms, and what have you noticed, and what have you tried so far?
Which gas valve does your water heater have? Please open typical manual and view images of the three basic gas valves.
When was water heater last serviced and cleaned?
How old is water heater?
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | RTO Bradford White M-1-20U6SS 19 Gallon...
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
Jul 28, 2011 | Fasco Bradford White Hot Water Heater...
Bradford White M250t6ds-1ncww 50 Gallon Electric Water Heater - Ta Logo
108 people viewed this question
Top Bradford White Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
