Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Samsung refrigerator rs267tdbp nat cold freezer working fine
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I had the very same issue. The freezer is actually responsible for cooling the fridge via fans. On the back of the fridge there's an access panel near the top containing 2 boards. The large one is the control bd. Make note of the connections and remove the board. Right where these fans plug in there are 3 switching transistors and a power regulator. Replace all 4. This is a common issue. A good place to get these is at digikey.com. even with shipping they only cost less than $10 USD. Also, on replacement, put a THIN coating of heat sink compound. You can get it at the same place or Radio Shack.
Posted on Sep 11, 2014
walterkunesk
  • 683 Answers
SOURCE: Refrigerator is not keeping food cold. Temp is set
Most refrigerators have the evaporator in the freezer and use air flow to cool down the refrigerator compartment. Can you tell if the defrost cycle is working, IS there ice on the evaporator. Can you defrost it. Try taking it off the power freeze cycle and also power cool cycle. When you cleaned underneath did you find a pan that had water in it. sometimes the drain clogs up and the condensate just sits in the freezer and refreezes the water, this acts like a blanket and slows down the cooling in the refrigerator. see if you can look at see if the drain is clogged, this may be your problem. You can get back to me and i will see if i can help you. thank you. and a rating would be helpful. thank you. wally
Posted on Mar 15, 2011
diodeic
  • 1622 Answers
SOURCE: my samsung rb1955vq refrigerator is
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 Phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
I hope this will help in solving the problem....
Posted on Jun 09, 2011
heatman101
  • 43501 Answers
SOURCE: samsung refrigerator model rs2545sh/xaa.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 12, 2011
heatman101
  • 43501 Answers
SOURCE: Hi, I have a Samsung
heatman101
Posted on Sep 04, 2011
SOURCE: Samsung sidexside refrigerator model RS263TDBP refrigerator warm freezer fine. Replaced fan on refrigerator evap coils, still not working. Help
Check the diverted box in fresh food side. Some of them have an electric flapper that opens to let cold air in to maintain temp in fresh food side. If coils are not frozen up then that is the next thing I would look at. The flap might not be opening up,
Posted on May 17, 2012
Freezer is fine. fridge side does not get cold
Samsung sxs refrigerators usually have a dual cooling system. That's why the freezer works fine. Refrigerator side could have a clogged drain or a defrost problem.
Feb 14, 2015 | Samsung RS265LBBP Side by Side...
How do you access the fans(s)that transfer cold air from the freezer coil to the fridge? Samsung RS267TDBP
The cold is transferred by the gas coils . there is a fan to cool the hot gas at the compressor . some freezers have a fan to circulate the cold air in the freezer , they don't transfer the cold from the compressor.
Nov 13, 2014 | Samsung Refrigerators
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
heatman101
Sep 03, 2011 | Samsung Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
My fridge is leaking water in the fridge then doesnt stay cold. Freezer is working fine just not fridge.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Samsung Refrigerators
Fridge side not cold on lowest setting, freezer side is working fine any suggestions?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 16, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Apr 28, 2010 | Refrigerators
Samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Apr 14, 2009 | Freezers
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
123 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
