Question about Universal SoftwinerEvb Capacitive Android
Softwinerevb updates Can I update the os or upgrade? Lots of little problems.
My Nexus 7 tablet says no updates but is only running android 5.1.1. How do I get it to update to latest android version?
Hi if you're tablet is a 2012 model it will not work with the Android 6.0 marshmallow update......Go to Google search type in HOW TO INSTALL ANDROID 6.0 MARSHMALLOW on your Nexus tablet,..... Cheers
Jan 05, 2017 | Tablets & eReaders
Just upgraded iPad 3 to iOS 8.1.1. Now everything freezes up. iPad won't even turn off at all. Is there anyway to reverse an update?
My iPhone upgraded fine. Try a hard reboot - hold power and home together until it goes off, keep holding until you see Apple logo then release and let it finish booting. If that doesn't work, may need to force a reinstall of the update via iTunes.
Nov 20, 2014 | Apple iPad 64 GB 3G Tablet PC
How do I upgrade my disgo9200 to kitkat
Android 4.4 is available on some devices out of the box. You can tell by looking at the notifications bar at the top of the screen. If you're on 4.4 then all the icons should be white. Earlier versions appear blue.
If you want to double check, head to the settings app on your phone and look for About Phone under System. Scroll down a little and you'll find the Android Version bar which lists the version currently running.
Despite being released last year, only a handful of Android handsets currently use Android 4.4, though the list is ever-growing. First, you'll need to check online to see if your device has the update. You can either do this online or on your gizmo. For the latter, head to the Settings app and find About Phone under System. From here press System Updates. Your phone will do a little searching and either find the update or tell you the software is up to date.
A huge array of handsets from major manufacturers including (but not limited to) Sony, Samsung, Google, HTC and LG already support the upgrade to Android 4.4, with more being added by the month.
3. Check the update is ready on your phone
Even if the update has been released for your make of phone/tablet, it may not have come to your individual device just yet. Usually the phone itself will notify you when the update becomes available via the notification bar at the top.
Again, you can check yourself by heading to Settings, finding About Phone and pressing System Update.
4. Time to download
If your phone is compatible, downloading the update is very, very simple. Either find the notification about the update and tap it or head to Settings, scroll down to find About Phone, press it and find System Update. Follow on the onscreen instructions and your phone will reboot itself with sparkly new.
Oct 28, 2014 | Tablets & eReaders
How do I get iOS down loads to down load on my IPad? I can't do anything unless I have ios6 or higher. I have first gen IPad.
Oops,
Heidi, again.
My excuses you already did put the most important things here.
Right. The first iPad, only can install iOS 5.1.1 If you go to settings, general and then to the second line Software update, it says (should say) iOS 5.1.1 software is up to date.
And yes. Lots of apps now on the market, are written for the newer iOS's Latest version is iOS 8.0.2.
But these iOS's and modern Apps, need fast processors and a huge memory.
Apple now has the A8 processor, must be the eight generation of processor and the memory where the programs (apps) are running in, now are 4 times as big as in 2010, when the iPad 1 came on the market.
I still see lots of people use the iPad 1 and as long as they don't want newer apps it is still a great machine.
If you really want to run the new apps, you better wait a few weeks, because Apple will announce the new iPads soon.
Even if you don't want the newest, the other versions will become a little cheaper, as soon as the new iPad(s) are on the market.
Dont buy a iPad 2 any non retina, because they will be in the same situation (not possible to upgrade) soon.
Be aware, Apple is bringing new iOS's almost every year, and the devices, still powerful enough can upgrade without any problem. There is no Android firm, who delivers major updates for their older devices. If you want to update, you must root the device first and then you can install other operating systems, with the risk the device never works as it used to be. For this you should have lots of knowledge about computers and work through lots of frustration, if it does not work the first time you install a rooted android version. And there also is a limitation. When the processors become faster and the memory increases, the older devices can't use the newer rooted versions either.
Oct 12, 2014 | Apple iPad 64 GB WiFi
Ipad upgrade problem
- the update procedure depends on the model of your iPad:
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer.
- but this model supports only iOS 5 - NO iOS 6/7/8
for all other models:
There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
- or directly from within the device, but only snce iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
ipad-upgrade-problem-ziidwqfjzh12fiagolk42ia4-3-0.jpg ipad-upgrade-problem-ziidwqfjzh12fiagolk42ia4-3-2.jpg ipad-upgrade-problem-ziidwqfjzh12fiagolk42ia4-3-5.jpg
Aug 25, 2014 | Apple iPad Tablets & eReaders
How to get on my iPad a 5.0 or a 6.0 ios
First Generation iPads can use iOS 5
- but iOS 6 / 7 / 8 need an iPad 2 or newer and are not compatibel with first gen. iPhone
-updates can be made in iTunes connected to a computer or under settings - general - software update
Upgrade iOS from within iOS device
(valid for iOS 5 and above)
Since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update). To upgrade to iOS 6/7/8, simply navigate to Settings > General > Software Update. The screenshot below demonstrates how to do so on an iPad, but this is also valid for the iPhone and iPod Touch.
in iTunes:
get-ipad-5-0-or-6-0-ios-fsa0em3gpfye3khtm1m3hcbs-2-2.jpg How to update to iOS 7
Jan 03, 2014 | Apple iPad Tablets & eReaders
My softwinerEvb tablet freezes when i turn it on
press power and volume up once the dead android appears.
Then install adb driver for windows and plug your tablet to an usb port of your pc. Next find Livesuite for flashing allwinner A13 tablet with a new rom.
It doesn't work for me, but still working for many people on web...
Jan 29, 2013 | Universal SoftwinerEvb Capacitive Android
User Manual for SoftwinerEvb 7" Android Tablet
no encuentro el icono de utilerias para configurar la tableta
Nov 27, 2012 | Tablets & eReaders
Is there going to be an upgrade to Android 2.2 OS?
Yes. it is out now. Now we are waiting for 2.3 update. cheers.
Jan 27, 2011 | Coby Kyros 716829701508 Tablet PC
Universal SoftwinerEvb Capacitive Android Logo
96 people viewed this question
Top Universal Tablets & eReaders Experts
rhodesworks
Yoav Shilon
Yoav Shilon
Lesley Cameron
Lesley Cameron
Are you an Universal Tablet and eReader Expert? Answer questions, earn points and help others
