Question about Krups Nespresso 554
Nesspreso machine tray filling up with water, coffee coming out very slow
3 Suggested Answers
SOURCE: no coffee
I had a similar problem with my XP 7240 with the coffee not coming out, but dripping through the machine and out the back. I found that overtime, there was a buildup of coffee in the "pod" area or percolation chamber and this was not properly removed. As a result, with additional cups being made, there was so much coffee compacted that it couldn't drip through.
I managed to clean it out by breaking up the compacted grains and it all worked fine. I also find that after each cup made, there is always some coffee grains left on the coffee cleaning tray above the grounds collector. I figured that this was the culprit as these grains would drop into the percolation chamber - adding this to the normal amount of coffee grains. It was never effectively cleaned out.
Now, I remove that tray after each cup, empty the grains and it seems OK. It's a pain, but I haven't had the problem for 2 months now.
Every now and then, I also get the vacuum cleaner and try to **** anything that might be oin there out.
Posted on Apr 17, 2009
  • 5 Answers
SOURCE: krups orchestro art889 water is coming down
Most likely the main O-rings have to be replaced. There is an excellent step-by-step instruction available on http://www.kaffeemaschinendoctor.de/Downloads:_:30.html under Jura, Aeg, Krups - It's in German, but Google can translate it. This repair is not for the faint at heart, but it can be done. The O-Rings can be found in any decent hardware store.
Posted on Oct 04, 2010
The water in my Nespresso does not come through the from where the pod is, but fill the drip tray! what is wrong?
I had a coffee machine that was letting out the water instead of making the coffee it turned out the hose that leads the water was disconnected from the source if you can get to the hose you may find the problem good luck
Jan 03, 2015 | Nespresso Coffee Makers & Espresso...
Barista supremo thinks it doesn't have coffee beans
http://www.espressotec.com/media/downloads/57/SA1260_Odea_Giro_plus_manual.pdf The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
Pump machine does not feed water from the reservoir and it's brand knew, it was offered steell has the seals. I don't have the warranty. Is it broken?
Feed some water with some pressure from the water reservoir hole. You have an air bubble. I followed all the solution ideas but no one worked for me until I designed my own idea. I attached a hose to the hole, opened the faucet and then put the nesspreso pump on and instantly the water come out. Solved problem
Sep 05, 2012 | Nespresso Essenza C100 Espresso...
My machine mark alternativley ventilate and fill water tank. I ventilate and I fill the machine and the message don't dissapear. With this display, I can't make any coffee. My email :...
Remove the bottom of the coffee maker, identify two rubber tubes and check to see if one has come loose or is simply not on tight. A simple reattaching of one of the tubes will work.
Another reason could be draining hole getting clogged with coffee grounds. When this happens it is easily fixed by removing the brew group and overflow tray; find the small drain at the back that drains excess water into the overflow tray and opens it up with a pipe cleaner or tooth pick. Flush out any coffee ground behind that hole.
Hope this helps.
Shane
Mar 06, 2011 | Saeco Spidem Trevi Digital Plus Fully...
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Water is pouring out of deteregent tray on fill up
inside the washing machine there drain from the detergent tray to the washer, it is plugged by a piece of clothing. remove the clothing and all should be fine.
Jan 01, 2009 | Kenmore 43142 Front Load Washer
Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Krups Nespresso 554 Logo
35 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
