Question about Roper RT21AKXKQ Top Freezer Refrigerator
RT21LMXKQ06 what is cubic footage - Roper RT21AKXKQ Top Freezer Refrigerator
What is cubic footage of this washer?
What is cubic footage Hale, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Refrigerators
I need to know that the cubic size is and the wattage for this model. Thanks.
Hello friend, thank you for your post!
Based off the information you have provided you would like to know the cubic size for your Frigidaire microwave, FMT148GP. The cubic footage of this particular model is 1.4 cubic feet. Hopefully this information is helpful to you. -Matt
Jan 06, 2016 | Frigidaire FMT148GP Microwave Oven
WHAT IS THE SQUARE FOOTAGE OF A 14 BY 70 MOBILE HOME.
Hi Sharee:
The square footage is 14 times 70 equals 980 square feet.
That would be the Floor Area.
Air conditioners sometimes need to know the building volume so if you have 8 ft ceilings you would multiple 980 by 8 to get 7,840 CUBIC FEET.
Air exchange is typically are rated at cubic feet per minute and required as "specified Air Changes per Hour.
An example for your trailer would be 1/2 air change per hour required per building code. 7,840 times 1/2 equals 3920 cubic feet per hour. Divide that by 60 to get 65 cubic feet per minute.
That would be the minimum air change capacity for your air conditioner if it was also providing required ventilation.
May 17, 2015 | Heating & Cooling
How many cubic feet is the frigidaire FSE447GHS0 front load washing machine
Good Afternoon friend, thank you for your post!
From the information you have provided you need to know the cubic footage of your Frigidaire washer, FSE447GHS0. I have researched your model and it appears to be 4.4 cubic ft. I hope this information is helpful to some degree. -Matt
Feb 25, 2015 | Frigidaire Refrigerators
I want to buy a refrigerator. I have a space 66 high by 30 wide, 40 deep. What cubic footage of refrigerator will it accommodate?
firstly, you do not mention the unit of measurement but that isn't the issue here as cubic footage can vary between manufacturers and models so nobody can give you a definitive answer.
basically, look at the dimensions of the one you're interested in, if it's within the figures you've got then it fits.
Nov 28, 2014 | Refrigerators
How to calculate cubic feet
Typically you can locate the cubic feet by multiplying length, width, and height. If you would like for me to double check the cubic footage of your appliance, could you please provide me with the model number? With that information I can better assist you. I look forward to your response. -Matt
Aug 27, 2014 | Frigidaire Refrigerators
WHAT IS THE CUBIC FT?
Good Morning Friend,
I understand you are looking for the cubic footage on your Frigidaire refrigerator, model# FRT15GB4. Per the specifications manual, your appliance is 14.8 cubic feet. I ask that you please follow up with a comment on the post, at your convenience, to advise of further questions. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FRT15G4B Top Freezer...
How many cubic feet is my ge fridge, TFX25JP?
The first few numbers in the model number indicate the cubic footage...so that refrigerator is 25 cubic feet
GENE
Sep 08, 2011 | GE Refrigerators
How do you calculate how much free air is required for a 50,000 btu wall heater
Calculate the Cubic Footage of the area to be heated (i,e. Total confined space square footage x ceiling height = Cubic Footage). So let's say the total cubic footage is 3.808. To be considered unconfined space in this example, the total maximum aggregate input rating of all gas-fired appliances installed in the 3,808 cu. ft. space must not exceed 76,160 BTU per hour; (3,808 divided by 50) x 1,000 equals 76,160 BTU per hour.
Normal air infiltration into a confined space will be adequate to supply the necessary fresh air for proper combustion and ventilation if the building is not constructed unusually tight. If it is tightly constructed, some type of fresh air intake should be installed. Being that this 50,000 Btu wall heater is required to be vented to the outside, you can figure that up to 20 to 25% of the heat produced is going up the stack or chimney. That leaves you with a total of 37,500 Btu's dedicated to heating the building.
Placement of the wall heater can be critical in even heat distribution. Of course, it will always be warmer closer to the heater.
I hope this helped answer your question. Thanks for choosing FixYa.
Aug 12, 2011 | Fedders Heating & Cooling
I am looking for the specifications like cubic footage on my chest freezer
The model number indicates the cubic footage of the freezer.
Example...model number xyz186xxww.,would be 18 cubic feet.
Post your model number on this thread for an exact conversion.
Sep 18, 2010 | Freezers
Roper RT21AKXKQ Top Freezer Refrigerator Logo
104 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
