Question about CECO Sinks Home
Porceleum stains - CECO Sinks Home
Can I use a oil base primer such a as kills over a oil base stain ?
yes u certainly can it will take care if it the next day primer it just sand it a little if your stain doesn't look good stain it again or put some stain in polly urethane and brush it on they do sell poly with stain already mixed
Jan 14, 2018 | Cars & Trucks
How to get blood out of carpet?
hi Connie.
Check out the instructions below.
  1. If the blood stain you're trying to remove is dry, go ahead and brush it with a steel brush to loosen the stain. ...
  2. Mix one teaspoon of hand dishwashing detergent with two cups of cold water.
  3. Take a clean, white cloth and dip it in the detergent solution you just mixed.
More items...
How to get Blood out of Carpet - Remove Blood Stains From Carpet ...
spotremoval.coit.com/how-to-get-blood-out-of-carpet
How do you remove blood stains?Follow These StepsWet the stain with cold water. If the stain is fresh and still wet, soak fabric in cold water immediately.Rub with soap. Rub the stain well with a bar of soap, lathering gently. ...Re-soak the stain with a pre-treatment stain remover. ...Dab on diluted ammonia. ...Launder fabric.How to Clean Blood Stains Video and Steps - Real Simplehttps://www.realsimple.com/home-organizing/cleaning/cleaning.../remove-blood-stainsSearch for: How do you remove blood stains?
or try this link.
How to get blood out of carpet Google Search
Nov 26, 2017 | Health & Beauty
How do you get rid of stains in the bowl?
Use a product called "CLR"
Oct 22, 2016 | Home
Remove cieling water stains from prior leak
use a solution of bleach and use a spray bottle to spray on the stain
just leave it ( no wiping, rubbing etc ) and in a few days the stain will be gone
there is a product on the market that is advertised to remove stains on ceilings but bleach did mine
Oct 26, 2015 | Cars & Trucks
How to remove grease stain from laundered shirt
How to Remove Grease Stains ' Stain Removal
www.howtocleanstuff.net > ... > Clothing & Fabrics > Stain Removal
Begin by blotting with a clean cloth to remove as much of the grease as possible. ... If your clothing is durable, spray oven cleaner on the stain and let it set for ...
Oct 07, 2015 | Washing Machines
How to stain wood veneer
You would need a stain that would penetrate the wood veneer. A good oil based stain should be able to penetrate all the way through. Lightly sand the face of the veneer with 220 grit or higher sand paper. I use a sanding block made out of rigid foam and sand by hand. You will need to keep the veneer wet with the stain until it penetrates. I would stain both sides of the veneer until it penetrates to the depth you desire and then wipe off any remaining stain. You may need to press the veneer until it dries thoroughly! Good luck.
Mar 21, 2014 | Crafts & Hobbies
My hp laptop stain problem, how to solved this problem please help me ?
Stain problem? I'm assuming you mean to say that you have a stain on the laptop somewhere? depending on where the stain is and what materials your computer is made of, the cleaning process can be dramatically different.
No one accurately tell you how to clean a stain without knowing what materials you have stained and with what substance you've stained them with.
Aug 04, 2013 | Computers & Internet
Blood stain on my pants
Blood stains are considered to be organic stains because they contain proteins. Protein is the building block for nearly every living thing on the planet, but it's also what makes removing a blood stain difficult. Proteins react chemically and bind to one another; typically, you can't remove blood stains completely using traditional stain lifting methods. To remove blood stains from clothing, avoid exposing the garment to heat or hot water. Opt for using a natural enzyme to lift the stain instead of using bleach, or other chemical stain lifters.
Apr 11, 2013 | Health & Beauty
Home Logo
26 people viewed this question
Top CECO Sinks Home Experts
john h
Tom Chichester
Are you a CECO Sinks Home Expert? Answer questions, earn points and help others
