22 Other Users Have The Same Problem - Continued
Comment by Long Day, posted on Jan 28, 2009
Ghosts in my printer. I think they are evil. I may need an exorcist.
HP 2600n
Comment by Guest, posted on Jan 21, 2009
HP Color Laser Jet 2605dn with same problem. Black is good, but CYandM all appear shifted between 1 and 2 mm to the right. Yes, I know, don't by remanufactured toners (and believe me I won't again). Printer is about 2 years old with less than 5K prints. Have found some sites which contend it could be the transfer belt. I'm a copier tech, so if you have a solution feel free to get technical with it. Thanks.
Comment by Guest, posted on Jan 17, 2009
I have the shadowing issue also, although it is from mostly cyan and black. I am diung the firmware update. Think it might be the transfer belt????????
Comment by paarse_olifa, posted on Dec 03, 2008
Colors not aligned anymore after toner replacement
Comment by Jerome2, posted on Oct 30, 2008
Any colours using majenta have the majenta component shifted about 2 mm down the page. (HP2600n) I have had the problem before and it resolved, but this time reinstalling driver, cleaning, calibrating etc do not correct the problem. Magenta is 60% full. Help[ would be appreciated.
Comment by joachim556, posted on Oct 18, 2008
Misalignment of the different colors and the black. Suddenly appeared - no clue what is the origin of it.
--spacefox
Comment by mdr_hashim, posted on Aug 12, 2008
all 4 color out of alignment. please help me
Comment by sydsowy, posted on Mar 28, 2008
still not working even with firmware upgrade!
Comment by MIRV, posted on Mar 18, 2008
Print quality troubleshooting page has all colors slightly to the left outside the black box. The black print cartridge band is also outside the left edge of its box. I've changed cartridges, ran calibrate, reset to the default, but nothing fixes the problem.
Comment by Guest, posted on Feb 25, 2008
Same problem on HP2605dn - calibrating didn't fix it.
Comment by Guest, posted on Feb 19, 2008
the black is perfect but all the clours on the hp colour laserjet 2600 are off alignment to the right. It has created a shadow effoct and is not sharp. How do you fix it
Comment by Guest, posted on Feb 12, 2008
The colour printed on the paper isn't what is suppose to be even after doing all the cleaning in the maintenance for the printer
Comment by mapinho, posted on Dec 26, 2007
To me the black is not aligned. I try the firmware update, but the problem remains
Comment by cacad, posted on Dec 17, 2007
My color registration is off also, I calibrated the printer three times and the registration actually seems to have gotten worse. It apprears more misaligned on the left side of the page. Any solutions?
Comment by zaphod777, posted on Dec 11, 2007
my cyan alignment is off on my HP 2605dn and it won't align even with a new cartridge or going through the alignment cycle 3 times.
Comment by Treens, posted on Nov 19, 2007
I have just changed the ink cartridge and it tells me that the colours are out of alignment, which they are. I've taken the cartridge out and popped it back in and done the alignment test three times and still no success, can you pls help me?
