Question about Stihl Garden
Sthil hs 81 t blades don't move - Stihl Garden
I have The same problem,after opening the gearbox cover found that one of the connecting rods bearing cage broken and needle bearings everywhere and both thrust plates damage . In order to get it fix will be as well buy a new trimmer.
Posted on Feb 20, 2016
2 Suggested Answers
  • 6468 Answers
SOURCE: blades will not operate when engine is running on my HS 81-R hedge trimmer
check the gear box where the motor meets the drive
Posted on Mar 30, 2012
How do I change the clutch drum on a stihlHS81R hedgtrimmer?
I have upload the SM for this unit to my google drive so be able to view and download it from there.
STIHL HS 81 86 RA 442 00 01 01 pdf Google Drive
Nov 08, 2014 | Stihl Garden
Blades do not move when engine running on hs45 sthil
Look for grease Zerk
xxxxxxxxxxxxxxxxxxxxx
May 20, 2014 | Stihl Garden
Stihl hs86 set blade gap
You shouldn't have to set a gap.. the gap between the blades is 'pre-determined' by a spacer between the blades that each 'blade bolt' passes through. You should be able to tighten up the blade bolts and the blades should still move. If they dont, then the spacers are worn and need to be replaced.
Apr 02, 2014 | Stihl Hedge Trimmer Pruner Cutter Blade...
Stihl HS 81 RC
You may be trying to cut material that is too large
Oct 05, 2013 | Garden
Motor runs but blade stops 1" into the wood
Seems like it could be a clutch/drum issue. I have known clutches to break through the threads in the crank shaft so they appear tight but are actually broken. I'd look at the drum assembly to see why the drive to the chain is slipping.
Feb 17, 2013 | Stihl 009/010/011 Clutch/sprocket
MY sTIHL hs 81T HEDGE TRIMMER IS DIFFICULT TO START, AND THEN CUTS OUT WHEN THROTTLE IS OPENED AFTER A WHILE
Sounds like a fueling problem, Could either be over fueling or under fueling. Is fuel making it into the cylinder.? Is the plug excessively wet.?
Aug 04, 2012 | Stihl Hs 81 T Hedge Trimmer Cylinder Hs81t
I bellieve I have sheared a pin or bolt. The trimmer runs fine but the teeth do not move. Any suggestions. Is there a operators manuel online?
Had the same problem with my Stihk hs 81 R hedge trimmers. Ive stripped it down and found that the clutch drum had sheared. Hope this helps.
Apr 28, 2012 | Black & Decker 22 In Dual Action Hedge...
Blades will not operate when engine is running on my HS 81-R hedge trimmer
Mar 29, 2012 | Garden
Garden Logo
291 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
