Question about Swisher Garden
Lawn sweeper Need parts for Swisher 48" lawn sweeper model 12048. 2 wheels P/N 12763
5 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: i need a belt diagram for a 60 inch Swisher lawn
There is a good repair manual here:
http://www.manualnguide.com/dl/3425/
Posted on Sep 22, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for manual for a Craftsman lanw sweeper
You can go to www.searspartsdirect.com and download a manual for it to either save to your computer or print it out or both
Posted on Sep 26, 2009
SOURCE: i have a 42 in. lawn crafter tow behind lawn sweep...
You can try Stens online or find a local repair shop that buys parts from Stens and order through them.
Posted on Jul 01, 2010
SOURCE: where could i find a manual for the Swisher Sp - 3...
need manual for swisher SP-38 lawn sweeper
Posted on Nov 23, 2010
How do I remove the wheels of a Ryobi Push Lawnmower model Pm400 as the blade has stopped rotating and I need to locate the problem
i think on this model the blade is driven by a friction clutch powered by the forward pushing of wheels , the clutches are inside the hub , the wheels are held on by small horseshoe clips under the dust caps on center of wheels (they pop off) , shafts are keyed to wheel , ive done this before because ive got there lawn sweeper and it works allmost the same way
Feb 14, 2015 | Garden
I have a craftsman lawn sweeper 32 inch pulling it forward the wheels slides
  1. The sweeper wheels or axle (if live axle) need servicing and lubing if they do not turn freely.
  2. If the sweeper from end rides too low, the sweeper will essentially be dragging, possibly with wheels elevated slightly out of contact with ground. Remember, the ground is what turns the wheels. One way would be to raise sweeper hitch tongue by inserting washers between tongue and mower hitch.
  3. If all check, adjustment, and lubing does not correct, consider putting weight on the seeeper or in the sweeper collector to put more weight on wheel contact with ground.
Nov 08, 2014 | Garden
Swisher manual
I BELIEVE IT'S 22 INCHES I JUST REPLACED MINE, SEARS HAS THEM OR YOU CAN GET THEM AT SWISHER.COM WITH PART #6046 FROM THE MANUAL OFF THEIR WEBSITE. I'M FINDING I HAVE TO ORDER EVERYTHING SO I'M GETTING 2 OF WHATEVER I NEED AT THE TIME
Jul 29, 2014 | Swisher 60" 13 Hp Trailmower #T1360h
Gas is leaking from the primer on my swisher walk behind trimmer. What would cause this?
i believe you have a cracked primer bulb or cracked fuel line. you should also check and see if the screws are loose that connect the primer bulb to the assembly.
Sep 25, 2013 | Swisher Walk-Behind High-Wheel String...
The hydro drive doesn't have much power
YES IVE SEEEN IT BEFOR SOUNDS LIKE THE BELT IS LOOSE
Jul 16, 2013 | Swisher Zt2560 Zero Turn Radius 60" Riding...
I need replacement parts for my 60" Swisher Trailmower / model T1360B1 When I went to the Swisher website, it says its obsolete. Where can I get parts.
I RECENTLY BOUGHT A USED SWISHER FOR $700 13.5 HP 60 INCH I BELIEVE THE MODEL IS 1340D? I'M HOPING I DIDN'T GET RIPPED OFF AND THIS IS SOMETHING SIMPLE..I THINK THAT'S THE MODEL NUMBER I'M NOT EXACTLY SURE THE STAMP O N THE SIDE ISN'T TO LEGIBLE , ANYWAY WHEN I SPRAY STARTING FLUID INTO THE AIR FILTER IT RUNS BUT THEN STOPS. IT HAS A NEW BATTERY, FUEL LINE AND FILTER AND I JUST TOOK THE CARBURETOR OFF AND SPRAYED IT OUT WITH GUNK CLEANER TO NO AVAIL. THE FLOAT BOWL WAS REALLY CRUDDY. I'M WONDERING WHERE I CAN GET A NEW CARB? ARE THEY AVAILABLE? IF SO WHERE? THANKS
May 05, 2010 | Swisher 60" 13 Hp Trailmower #T1360h
Garden Logo
103 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
