Question about Harman Kardon HK19.5 Computer Speakers
Buzzing coming from speakers
A loud buzzing sound is emanated from my speakers whenever i turn them on. Volume level makes no difference. The speakers aren't even plugged into my computer. Ive tried messing with wires, unplugging/replugging, making sure electronic devices arent near. please help
jackboy
  • 2985 Answers
SOURCE: Harman Kardon Elegant 2.1 speakers problem
'Sounds' like you have overwhelmed the cone and split it or a solder joint has come adrift Don't know about repair or replacement -Check makers website.
Posted on May 13, 2007
jackboy
  • 2985 Answers
Chances are you have wrecked the cone and movement with the overly high input. Nor repairable if this is the case. Check out the makers website for more tech info
SOURCE: Speakers Make a Very Loud Noise that Increases
speaker amplifier chip may leaky or damage
you are using improper sound driver
check driver status in your computer device manager or just typing dxdiag on run in start menu, check status of sound driver installation
Posted on Jan 17, 2008
Jowinson
  • 16 Answers
SOURCE: Left speaker not working...
I am supporting TIRZO by adding that you can open the left speaker case and check the wire that leads to the main speaker, I hope the fault should be from the connection between the main speaker and the green light that is on.
Jowinson
Posted on Jun 20, 2008
  • 4 Answers
SOURCE: My computer speakers just went silent in the middle of a song
Try this - you can generate a test tone throught the DIAG port on the back.
http://support.dell.com/support/edocs/acc/20cku/en/diagnost.htm
Posted on Apr 23, 2009
Subwoofer is buzzing when volume turned up just past middle level-in other words it doesn't take much for the subwoofer to start buzzing
You may have overdriven the woofer at some stage, and torn the cone. Once that happens, the tear will start flapping (buzzing) whenever the volume is high enough to vibrate it loose.
If thqat's the case, you'll need to replace the woofer inside the cabinet - or replace the set of speakers, which is probably more economical for you.
Jun 19, 2010 | Logitech LS-21 2.1 Speakers
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
When turned on tv makes a loud buzzing sound
Hi my name is Roety,
I can help you with your issue ,
If the buzzing comes from the speakers , raise the cable box volume lower Tv volume. If its coming from the back of the TV, check/replace power supply coils
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 28, 2009 | Televison & Video
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Samsung 7178 buzz noise
Is this buzz from the speakers?
Is this buzz from the set itself when the sound is turned down?
Is this buzz a low pitch sound?
Is this buzz a high pich sound?
Does this buzz vary in loudness with the volume control?
Does this buzz change in level from time to time?
You should post the details and the circumstances of use in order to give some idea of the conditions.
Jerry G.
Apr 16, 2008 | Televison & Video
Buzzing sound
The sound is a result of the faulty CRT base, and you will have to replace the base socket. Make sure you by the exact same type of base, and if you are not a techie, get a qualified technician, this is not a costly problem.
Jan 17, 2008 | Samsung HL-P6163W 61" TV
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Harman Kardon HK19.5 Computer Speakers Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
