Question about TP-LINK TL-MR3420 Wireless Router
Media server error 000001f7 - TP-LINK TL-MR3420 Wireless Router
How do reconncet to my server
Which error message? It probably a windows security setting issue. I have problems connecting to my DLNA server if I do so and a network share rather then as a media server for the same reason.
Sep 26, 2014 | Samsung Galaxy Tab Tablet PC
Whats the model and make of the media server. Best bet would be to consult the manufacturers site for the error code.
Nov 16, 2013 | TP-LINK TL-MR3420 Wireless Router
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
While performing multiple activities an error message says "The media is write protected" how remove?
Hello, Not sure what the media type is but I will assume you mean a tape drive as you are able to switch between write protect and writable. At the boot of the tape cartridge you should find a button that moves from side to side. You should be able to see "write" on side and when you move the switch you should see "Protect". If this is not the media form you are usings, repost with what type of media you are using. Good Luck.
Feb 22, 2012 | Dell PowerEdge 2650 Server
How do I get rid of error 404 on my ipod touch?
Hi, The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server but either the server could not find what was requested, or it was configured not to fulfill the request and not reveal the reason why. 404 errors should not be confused with "server not found" or similar errors, in which a connection to the destination server cannot be made at all.
error 404 comes most times when the client ison able to connect to the server...or the site is not accessible..
Not really a problem with your ipod, but with your internet browser...
Take care.
May 30, 2011 | Apple iPod touch
I keep getting error code 80710092
If this error message occur when trying to connect network just go to media server settings in your PS3 and disable the streaming media servers
May 29, 2011 | Sony PlayStation 3 (120 GB) Black Console
Im trying to log in the playstation network but the error code 807110092 shows up what do i do?
it seems to be a problem with a connection to the servers, nothin that we can do, we just gotta wait til they come back online again
May 29, 2011 | Sony Playstation 3 (PS3) Console
_how do i fix error code 80710092
There's no clear solution for this issue though it seems to typically involve Media Server Connection. You'll have to disable Media Server Connection by going to Settings > Network Settings > Media Server Connection. If you do use this feature often, you'll have to keep turning it off and on.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
TP-LINK TL-MR3420 Wireless Router Logo
279 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
