Question about Kenmore Dishwashers
Dishwasher not completely draining
Kenmore 665.13263k113 still has water sitting at the bottom of the dishwasher upon cycle completion...can't find any trouble shooting online, bought floor model didn't get a user guide. Please help
  • 183 Answers
SOURCE: shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Posted on Aug 05, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE: Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Posted on Feb 26, 2008
SOURCE: Kenmore dishwasher drainage problems
I have the same model -- and USED to have the same problem! We tried lots of things (bleach in the water, etc.). . . . and finally discovered it was a simple, standard concern. The drain tube from the dishwasher to the sink pipe was clogged with grease (looked like lard).
The way i knew it was clogged is that I disconnected the tube from the sink pipe, and tried to blow through the tube. It wouldn't let any air get through.
So once the dishwasher was empty of water (i removed the tube, drained into a big pan, and bailed a lot), we disconnected both ends of the tube.
With the tube in a trash bucket, I blew from one end (cleaned it off a bit first), and the "lard" came out. Drains beautifully now -- and did not require a plumber.
If you do this, be SURE you place the tube back ON the fittings EXACTLY in the same position and shape as before. This makes there are no new kinks or bends introduced into your drain tube.
Hope this helps.
E-mail if further questions!
Jonathan
Posted on Nov 28, 2008
SOURCE: Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Posted on Aug 21, 2009
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher does not drain completely
the cycle was interrupted and now it will not drain completely. I cannot find the instruction manuel, and when I push the "clear/drain" button I hear the motor start but then when the light goes off the water is still in the bottom.
Nov 06, 2007 | Kenmore 13743 Staimless Steel Built-in...
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
