Question about Everbilt Locks & Locksmithing
How to install a everbilt double acting hinge
The instructions for an everbilt double-action spring hinge are not correct how do you install the hinge properly?
4 Suggested Answers
SOURCE: MAYTAG (AMANA) OVEN DOOR
I finally got my door back on, I had to wedge a butter knife in the hinge to keep it open, then I could put it back on the pins and slide the metal cover/locking thinge over it. Was a pain in the ass.
DANGdoor
Posted on Dec 02, 2007
al_kupchella
  • 843 Answers
SOURCE: Can you explain how to
Aha, thanks for the clarification. So this is apparently a door between the kitchen and the dining room. It has been a few years since I was faced with the same problem, but if I recall correctly I had to stand on a ladder to get to the screws that attach the top hinge to the top of the door, then I was able to lift the door off of the lower pivot. If this doesn't do the trick, please post another reply. I may still have my old door with hardware still attached and I can go take a look at it. Good luck!
Posted on Aug 19, 2010
czaa
  • 4514 Answers
SOURCE: I need to rebuild the double action knee shock absorbers on my 48 Chev. I cant find any instructions
call 4076292661
Posted on Aug 09, 2012
I installed the Everbilt double action spring hinge. A YouTube video said the hinge needs to be oiled; the instructions do not say so and I see no hole for oil.
While the door is opening, part of the hinge as seen from the top will remain stationary and part will rotate with the door. Between them is where you'd put a few drops of oil. There's probably a couple of places this movement occurs. However, this probably won't be necessary for years but can't do any harm, especially if they get rained on.
Mar 13, 2017 | Miscellaneous
How do I adjust spring loaded hinges?
Using a drift punch that fits the hole , place drift into bottom hole.
Twist to increase pressure(one hole only. Reposition pin one hole tighter.
Repeat to other hindges.
Jun 11, 2014 | National Grid National Hardware V127...
How does one install this hinge properly?
1. Use somebody, or some clamps to keep the angle set while you mark and install the pieces. The angle is the most crucial feature. The other measurements are secondary to this.
2. Make other measurements from the center of the hinge where it pivots, not the edge of the box. When you use the center technique, you don't need to worry about distance from the back, only distance from the top.
3. With just the distance from the top and the angle set, position the top of the hinge in it's relaxed position as out of the packaging. Don't try to stretch or compress it into place. Keep the hinge as straight and square as reasonable. The rest of the measurements don't matter.
May 26, 2014 | Everbilt Hinge. Antique Bronze Universal...
Remove everbilt hinge pin
Support the door , remove screws from one leaf of hinge, use a 1/8" punch and tap the hinge pin from the bottom. If you use grease to reinsert make sure it's white lithium grease
Nov 24, 2013 | Everbilt Hinge. 3 in. Square Corner Hinge...
Just changed out brass Stanley 5/8 round door hinges for satin nickel finish Everbilt brand hinges. Most worked well, eg the door closed into the jamb as before the switch. However, sereval did not due...
Assuming these are regular **** hinges (like on full sized doors) as opposed to surface mount hinges (as on old style cabinets), you can try putting a paper shim behind the top hinge. This will tip the door away from the hinge just a bit.
Mar 10, 2011 | Garden
The hinge part of the toilet seat installed alright---but once the seat was connected to the tank, i tried to open the lid and it just fell off---the quiet close "dowels" for lack of a better...
Hi, Please don't take this the wrong way but did you install the hinges the right way? I fit bathroom suites for a living and have done this a few times wrong by putting the left hinge on the right side and vice verser. Sometimes the instructions are not very clear in explaining which side is left on the seat, as a result even though the toilet seat is closed, the springs are set backwards and are in fact in the up position. Double check the instructions once more, and just have a look on the hinges and seat because sometimes they have a small 'L' sticker on the hinge and an 'L' sticker on the seat and lid to correspond which hinge goes on which side. Hope this is of help to you.
Jan 11, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
I HAVE CHANGED BROKEN FLAP 2 MONTHS AGO BUT THE FUNCTION OF OPERATE SYSTEM AFTER CLOSE THE FLAP CANT WORK PROPERLY, SO PLEASE TELL ME WHAT CAN I DO?
Was the flap changed by a techician ?
I have played with my 1200 and thus
know the flap hinge area has two special aspects :
(a) embedded-into-hinge-on-one-side, a spring loaded mechanism, for the firm open-close action.
(b) a small circular magnet embedded within the hinge framework (this magnet working from the right location should be essential to trigger the answer-when-flip-open or disconnect-when-flip-is-closed systems).
So your problem could be due to one or both of these things not being (re)installed correctly.
Good Luck.
fixya[at]technife[dot]com
Nov 05, 2010 | Motorola Mobility A1200
Can you explain how to remove a door with a horizontal spring pivot, double acting floor hinge.
Aug 16, 2010 | Garden
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
Locks & Locksmithing Logo
120 people viewed this question
Top Everbilt Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an Everbilt Lock and Locksmithing Expert? Answer questions, earn points and help others
