PTAC COMPRESSOR NOT TURNING ON - Heating & Cooling
I have a Friedrich Ptac unit Model PDH15K5SE-A. The unit turns on ok but does not heat. Need advice what to do. Thanks
Does the unit cool ok? If yes, you likely have a problem with reversing valve. If no, likely a refrigerant problem.
Mar 01, 2017 | Friedrich Heating & Cooling
Arman ptac compressor doesn't want to keep running
is the system low on gas pressure
if not tripping the circuit board
will assume motor and all the electrical systems are safe
GREE 00101061 PTAC Rotary Compressor and Fittings
Jul 22, 2016 | Heating & Cooling
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Amana ptac- blows same temperature air whether its set at 80 or 65...any ideas?
Check to see if your compressor is running. Thre are 5/16 screws on either side of the unit holding it to the case. Take those out and you can get to the cpmpressor. These are not complicated units but you may have to have a service tech look at it for you. I do sell a lot of these PTAC units so if your compressor is running you have leak or bad compressor. Russ
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Freddrick ptac a/c unit comressor never comes on relay on compressor seems good,m what now?
Hi!! change you start capacitor also check for amps going into the compressor.if power is going then ohm out compressor.Short compressor..
Jan 19, 2009 | Heating & Cooling
Zoneline ptac
scrap the unit for alumimun and copper and buy a forty lol
Jul 10, 2008 | GE Zoneline AZ55H07D Air Conditioner
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
