Question about Inland 2.5" SATA to SuperSpeed USB 3.0 Portable External Hard Drive Enclosure
Cyclic redundancy check error inland 2.5" hard drive enclosure with usb 3.0
Data error cyclic redundancy check
This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
DATA ERROR (CYCLIC REDUNDENCY CHECK
crc errors means data corruption.
run scan disk on HDD.
Sep 19, 2013 | Buffalo Technology Buffalo MiniStation...
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
500 MB data error(cyclic redundancy check) external hard drive is not accessible
1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
2. This issue could be due to the data controller on the USB drive being defective.
3. try purchasing a new case with a new controller board.
4. Check to see if your 1TB USB drive is compatible with your pc.
Jun 13, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
The Samsung Freeagent GoFlex external hard drive is not recognized by Windows 7 OS. I tried to initialize disk under computer management / storage / disk management and got the cyclic redundancy check...
This is a good read on what this error actually means:
http://www.softwarepatch.com/tips/cyclic-redundancy.html
What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
May 03, 2011 | Seagate FreeAgent GoFlex Pro 500 GB USB 20...
I have 2 problems , the first is cyclic redundency (i can't copy files from my labtop to it) then after 2 days when i placed it in the labtop it couldn't be read by it ( it's name didn't appear)
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
If the hard drive is not detected by the sytem try if to a different usb. If still fails check the warranty of the drive then call the manufacturer or store you purchase it you might have a bad drive.
Thanks for using Fixya.
Feb 07, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Cannot Copy File:Data error (cyclic redundancy check).
Try to download" Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Inland 2.5" SATA to SuperSpeed USB 3.0 Portable External Hard Drive Enclosure Logo
14 people viewed this question
Top Inland Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
David Payne
David Payne
richie46
Are you an Inland Computer and Internet Expert? Answer questions, earn points and help others
