Question about Frigidaire FEB30S5D Electric Single Oven
Oven door sprung FEF450WBW-A the door doesn't close tightly
The oven door doesn't close tight
Hello, Anna -
The problem of your oven door not closing tightly could be caused by one of several problems:
* A problem with the door hinges
* Broken oven door springs
* A problem with the gasket inside the edge of the oven door
This article from the San Francisco Examiner newspaper describes the problems and how to fix them:
http://homeguides.sfgate.com/fix-oven-door-not-close-properly-28760.html
Best wishes.
Feb 07, 2018 | Ovens
How do you remove the door?
the spring is sprung now and will need to be replaced
Jan 10, 2016 | Ovens
Can not close the door
how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
Oven door seems sprung as if a spring may be shot and door dose not close all the way?
You need to replace both oven door hinges, as the springs are weak, and there is no adjustment available.
Sep 25, 2010 | Cadco OV-400 Electric Single Oven
Kenmore 790.49073400 oven door won't close completely
Hello- You are on the right track. The hinge assemblies are 'sprung' or bent out of shape. Replacing them is pretty easy, so you can do it yourself. Four screws on each side. Be careful, these springs can snap closed and bite ya. Use the little pins that come with the new set to lock hinge so this doesn't happen. Let me know if this info helps- have more if needed- Thanks- Ed
Mar 19, 2010 | Kenmore Ovens
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Frigidaire FEB30S5D Electric Single Oven Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
