Question about GPS
Roadcom rc300 how charge in mains - GPS
Can't program a MS-RC300 remote
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability.
If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 29, 2013 | Televison & Video
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
I need a instruction manual for roadcom
Here is your instruction manual in PDF form. http://www.cbradio.cz/doc/TEAM/RoadCOM/manualuk.pdf
Let me know if I helped.
Mar 07, 2011 | GPS
Cant program remote to zenith television
If it's an newer Zenith TV(LCD/PLASMA/DLP) it might be that the RC300 does not have the codes for the newer models, but if it's a picture tube TV(CRT) and the zenith codes given to you in the code list are not working try the code search procedure(scans and transmits all codes one at a time)you will have to turn your TV on to continue with this procedure. If you don't have a users manual you can download one from rca.com/accessories/universalremotes. You can also try the codes listed for LG, they could work.
Mar 10, 2010 | RCA RCU300WBL Remote Control
I have been having trouble with my roadcom sat nav, I used it to get somewhere and had no problems but when I went to turn it on to come home, the main screen comes up but it just freezes and it wont let...
To hard reset the unit turn the unit off, hold down the mode button and turn the unit on. When the unit asks if you want to erase all user data, select yes. After resetting the unit, leave it with a clear view of the sky for about 30 minutes to acquire the satellite almanac. “ Do not worry You don’t loose Your saved rides data, only all screen settings and some other device settings will go away. Set it back to Your preferences and You’re done. Hard reset is suggested after software updates. In my case it heals all self shutdown problems in my Edge 705 GPS.
Dec 02, 2009 | Garmin Edge 705 Satellite Navigation...
I inherited a Barnett RC300 crossbow and would like to find a copy of an owner's manual.
Email barnnet. They sent me one by Email yesterday. free of charge
Aug 17, 2009 | RC Toys
My acer aspire 5315 is stuck on dis screen, n I don't have a reco
Hello my friend, regarding on your problem it is clearly that your system cannot boot from its kernel part of the Operating system. It is experiencing a software corruption or corrupted files of your operating system. The only solution you can get is to re install your operating system to replace and repair any damage files in your operating system.
Thanks
Jul 16, 2009 | Computers & Internet
My acer aspire 5315 is stuck on dis screen, n I don't have a recovery disk to reformat it, wat can I do? Broadcom UNDI PXE-2.1 v10.0.9 Copyright (C) 2000-2006 Broadcom Corporation Copyright (C) 1997-2000...
your operating system is broken. or infected by virus, file corrupted.. neet to repair if could.. but if not re install the os...
save first all the inportand documents in external hdd or in drive d before to start re install the os
Jun 14, 2009 | Computers & Internet
GPS Logo
41 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
