Question about Jabra BT150 Wireless Headset
Chocolate phone will not discover the Jabra BT150
Hello! Okay, the problem I am having is that my phone will not discover the headset. This headset has been passed down to me, wasn't used much at all and I would like to use it. Ive fully charged it and it works, but I just cant seem to connect it with my phone. I have a plantronics bluetooth headset already so I'm wondering why I cant connect this one? How does the Jabra pair with phones?
  • 2 more comments
  • winston h Dec 08, 2007
    my phone will not find the jabra bce-bt150 headset
  • Anonymous Dec 25, 2007
    same with me. same phone and jabra.
  • Anonymous Sep 23, 2008
    samsung g600
  • mabasser May 21, 2009
    my blackberry does not pair up whit jabra bt150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Posted on Feb 13, 2008
SOURCE:
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
Is my phone compatible w/ the jabra bt150??
bluetooth headsets are compatible with any phone that has bluetooth to connect just while its off, holding down the power button untill a constant red light comes on. then searching for the headset
Mar 18, 2009 | Jabra BT150 Wireless Headset
Can't turn on ! no in structions w/ear peace. LG PHONE(chocolate) can't find ! BT150 Jabra ! I do'nt know wich buttons are what? how long it last, or when its charged ? H..E..L..P....!!!!
Go to the bleemin Jabra website! (http://www.jabra.com/Sites/Jabra/NA-US/Headsets/Pages/JabraBT150.aspx)
"When I put the charger on for the first time after purchasing and plugged it in there was just a quick blue flash but no lights came on ever."
This one is more fun. The charger that comes with the bluetooth WILL plug in 180 degrees from proper.
Symptom of reverse plug-in is usually a dull(VERY dim) blue glow and a high pitch whine. Depending on
the parts used in your production batch, one inverted plug-in could have popped something. Try rotating the plug 180 degrees, and seeing if the charging light doesn't come on(if it does, then you're good, if not, return for refund, or you're fubared)
Aug 11, 2008 | Jabra BT150 Wireless Headset
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
Lost instructions BT150 how to connect to phone?
1. Turn the BT150 on. To do this press and hold the answer/end button until the light flashes blue, then release.
2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds.
3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Goodluck
Apr 27, 2008 | Jabra BT150 Wireless Headset
Pairing
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Manual for Jabra BT 150
Go to page 4 Pair it with your phone
Did you know that if you have a bluetooth card in your computer you can also use this headset to listen to music. Do it everyday. It's great!
Mar 22, 2008 | Jabra BT150 Wireless Headset
Jabra BT150 compatibility
Went to Jabra could not find the number you gave for the phone. It is compatible with Nokia phones but does not show this number. Sorry.
There's a 6162 and it is compatible.
Let me know if the number you gave is correct.
Mar 02, 2008 | Jabra BT150 Wireless Headset
Jabra BT150
DO AS THAY SAID HERE.......Press power button and the - and + volume buttons at the same time AND THEN WHEN THE BLUE LIGHT STOPS ON !!!!! GO TO YR PHONE AND SEARCH FOR THE HEADSET WHEN U HAVE FOUND IT ON YR MOBILE TIPE .........0000...... then you will be sorted
hope this helps c ya
Nov 04, 2007 | Jabra BT150 Wireless Headset
Setting up pairing
# Fully charge your Jabra BT150 and switch on by pressing the answer/end button # Press the answer/end button and the volume up (+) button together, to put the Jabra BT150 in pairing mode # Set your mobile phone to ?discover a Bluetooth device? (see your phone user guide) # Press Yes or OK when asked if you want to pair the phone with the Jabra BT150 # Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK # Your phone will confi rm when pairing is complete
Jan 05, 2007 | Jabra BT150 Wireless Headset
Jabra BT150 Wireless Headset Logo
403 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
