Question about Pentax ZX-50 35mm SLR Camera
Battery nikon Need battery for this camera
Nikon L110 battery getting discharge in few clicks
It could be a bad battery charger circuit in your camera. Try charging your batteries in an external charger. Adorama.com sells an Delcon Devices external battery charger for $9.95. If that works, your problem is solved. If not, you will need to send the camera to Nikon USA for repair.
Jul 11, 2013 | Nikon Coolpix L110 Digital Camera
Nikon L22 camera will not power with new batteries
I would see if the camera works with disposable batteries. If it does, your battery charging circuit may be faulty. Are you charging the batteries in the camera or in an external charger? If it's in the camera, buy an inexpensive external charger and see if that works. If you eliminate the charger as the cause, the camera will probably need to go in for repair. Contact the Nikon Repair Depot listed in your camera's manual or on the Nikon USA website. They can give you a repair estimate.
Nov 28, 2012 | Nikon Coolpix L22 Digital Camera
How do i fix the battery exhausted problem on my camera: Nikon CoolPix L22?
Nikon cameras say battery exhausted when they need new batteries, just swap out the old ones and it should be good to go.
May 23, 2011 | Nikon COOLPIX L20 Digital Camera
My nikon coolpix camera battery dided and now when i plug it in to the charger it wont charge. is there some sort of reset i can do?
If you haven't use your Nikon Coolpix camera battery for a long time and now there is no power, when you first plug it to charger it maybe show none action. And charger longer it will be well. But if your battery Nikon camera battery are used well these days, and it won't be charge. It means you need a new Nikon battery charger
Apr 29, 2011 | Cameras
My nikon coolpix s220 wont charge... do i have to have the original charger???
The S220 uses the EN-EL10 battery. The camera does NOT incorporate any charging circuitry, so connecting it to a computer actually drains the battery. In order to charge the battery, you need the MH-63 battery charger or a third-party equivalent.
If you need a charger, you can order one from your local Nikon dealer or from http://www.nikonmall.com
Feb 21, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Low Battery Indcator Flashes
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Mar 01, 2009 | Nikon D80 Digital Camera with 18-200mm...
Pentax ZX-50 35mm SLR Camera Logo
15 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
