Question about Eureka 4495A Bagless Upright Vacuum
Clogged hose the hose is clogged
Clogged light staying on despite there being no clog, won't pick up anything with even just the hose.
If the light goes out if you disconnect the hose, there's something in the hose or wand.
Mar 14, 2014 | Dirt Devil Easy Lite Quick Vacuum
Lost suction but no cloggs in line
see the solution; God bless you
How to determine a clog in your hose
Take your central vacuum hose and connect it directly to the dirt canister. After turning on the vacuum if the hose has normal suction here then the clog exists in your tubing.
Click here for help with tubing clogs. But, if you experience reduced suction at the canister then your hose is clogged. See Solutions below.
check.gifPlug hose in reverse into the inlet located on your unit and turn on the system. This should aspirate the clog out.
check.gifOr, remove the hose from the inlet and push a garden hose through hose to push out the clog. Most importantly, the garden hose must be turned off and there should be absolutely no water entering your vacuum hose.
check.gifOr, remove the hose from inlet and drop in a heavy object such as a screwdriver to push out clog.
Jul 23, 2012 | Broan-NuTone VX475 Bagged Central System...
WHEN WE USE THE HOSE ON THE VACUUM DUST AND PET HAIR COME OUT OF THE HOLE HELP
A clogged hose is the most likely problem. Disconnect hose at both ends and try dropping a coin through it. If clogged, use a broom handle to push clog back through.
If the hose isn't blocked, check the tank where the hose attaches. Just inside clogs often form. Clean if necessary.
Check the filter, and change if dirty.
Mar 02, 2011 | Bissell Vacuums
I am experiencing some (not complete) loss of sunction when I use the hose
Possibilities:
Dirty filter, needs cleaned or replaced.
Partially clogged hose, needs cleared. Detach hose from tank and drop marble down the end of the hose. It should roll through the hose and power head to the floor.
Partial clog in the power head between where hose attaches and the brush. Detach hose from power head and drop marble into opening. If the marble doesn't roll through, there's a clog that needs removed. You may need to disassemble the power head to do so.
Leaky hose, needs replaced.
Clog between back of tank and filter. This is where the hose attaches to the tank. Remove clog.
Clogged filter at bottom of tank, needs cleaned. Remove tank. There's a screen at the bottom of the tank/vacuum. Simply remove/clean anything that may be covering/clogging any of the holes.
Dec 18, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Will not **** from hose to canister
The hose might be clogged.. Stretch the hose out streight to look down it.. Sometimes the clog is were the hose connects to the upper part.. Sometimes the clog is at the lower part - or maybe in the middle of the hose..
Jul 08, 2009 | Vacuums
Clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Clogged Bissell
Something must be in the hose causing a clog, take the hose off and if suction is good where the hose hooks up, then there is something caught inside the hose.
Mar 23, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Reverse Suction
You have a clog either at the inlet by the brush roll or in the hose. Pull the hose and check for suction at the end of the hose, If it is ok there, then you have a clog from where the hose hooked into and the inlet at the bottom. If at the end of the hose there is no suction, take the hose off and see if you see a clog in it. If no clog there, then check all filters, if they get clogged, then air can't flow thru them and no suction.
Dec 31, 2007 | Hoover U5507900 Elite Rewind Bagless...
Eureka 4495A Bagless Upright Vacuum Logo
13 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
