Trane twg030a140b1 what can I replace it with
Do you have the wiring diagram for this unit?
Posted on Jun 19, 2014
I have a American standard ac model 7A0018-60A100A and would like to know the model no. of the condenser fan motor so I can replace it
All you need to know is that it is a 1/4 hp, 825 rpm. 1/2 inch shaft. That is if you are going to buy an after market motor. I have had to make new mounting holes when using after market motors on trane systems (just the way trane is) but not a problem. If you're getting it from trane you would only need the model number of the condenser.
Jul 14, 2017 | American Standard Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
How to find the diagram wiring for Trane TWG030A140B1
http://www.trane.com/Commercial/Uploads/Pdf/1111/2_4tec3.pdf
Jun 19, 2014 | American Standard Acont200an11aaa...
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Aug 19, 2009 | Heating & Cooling
Hi I am replacing a trane thermostat it has 8
call hunter fan co. you will have to jump out some term.
Jul 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
