Question about Dometic Refrigerators
Model NDM 1062 Replaced refrigerator light assembly 4 times this year. Light not working
The refrigerator door light switch assembly has been replaced 4 times this year .The light is not working again. Switch was replaced just yesterday. Dometic model 1062
    Top Expert:
  • Dometic Master
  • 5,750 Answers
Possible bad socket
Posted on Nov 05, 2017
2 Suggested Answers
  • 68 Answers
SOURCE: Inside light switch to be replaced only by getting the product
I can get you a light switch, I may even have one in stock. Have replaced several.rvtech@myway.com
Posted on Mar 19, 2009
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
NDR 1062 Dometic Refrigerator
Not unless you unplug the thermistor from the circuit board and let it run for 24 hours. If it does not cool after that then your cooling unit is bad.
Dec 05, 2013 | Dometic NDR 1062 Refrigerator
LG LRFD22850SW light won't go out!
if you stay on the line and dont take no for an answer
they just might cover it for you
make sure you mention several times its a fire hazard
and just dont take no for an answer
Oct 08, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Not cooling on 120 V0lts
NDR 1062, cools with gas but will not switch over to Ac . If i turn off lp, check light comes on and doesn't cool
Jun 22, 2009 | Dometic NDR 1062 Refrigerator
Dometic RV refrig light will not go out
Open up the door to the freezer, you will see two black switches upper right just above where the door would be when closed. Flip the first switch, then push the switch on the light in the fridge compartment and the light should go out. Thinking that switch is there to help reduce moisture inside fridge, just got pushed by mistake and light remains on. Hope this helps.
Ron1247
Apr 08, 2009 | Dometic NDR 1062 Refrigerator
Jan 26, 2009 | Dometic NDR 1062 Refrigerator
Short in freezer?
IF THE WIRES SHORTED, AND THE DOOR WAS REPLACED,
WAS IT COMPLETE OR WAS THE DISPENSER ASSEMBLY TRANSFERRED TO THE NEW DOOR? IF THE ASSEMBLY ISN'T NEW, THE CONTROL BOARD IN THE ASSEMBLY MAY HAVE BEEN DAMAGED FROM THE WIRE SHORT.
Feb 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had the same problem. One morning I opened the doors to a hot fridge and burning plastic. The light housing was sizzling hot - much of the unit literally melting away. Another hour or two and it could have been much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes of patient talking, I learned that Sears (or Kenmore) have issued what they refer to as a "flash warranty) on the light fixture kit (Kit # 6871JB1423N) which in effect, for this part only, extends the factory warranty from one year to three years. I may even be able to have a factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
Feb 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
56 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
