Question about Garden
Ajust cutting deck
Wont stay in place
  • 51 Answers
Replace locking washers if equipped, if it has cables, replace both cables and possibly plastic pulleys
Posted on Nov 18, 2013
Husqvarna problems
Your deck either engages with a cable or an electric clutch, which one is it. Cutting deck engaged when started is a switch issue.
Jul 27, 2014 | Husqvarna Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
Jun 11, 2010 | Garden
Ajusting mower deck on husqvarva lawntractor been trying to make it level,has two cutting blades and this mower is not very old bought it last summer,
I think the two bladed units are 42" and down in size. The 48" are 3 bladed units. There are instructions in the manual for leveling the cut. If you do not have a manual, look on line for a manual, google it. First step is to get the mower sitting on a level piece of concrete. That way you know which corner needs to be raised or lowered. Then make sure your blades are mounted correctly. Usually you can see the adjusters, threaded bolts and nuts, or pins. Usually the deck comes level and gets **** up by someone taking the deck off to swap or sharpen blades.
Mar 06, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Saw wont cut streight ,cannot control cutting along a line
Is there an ajustment for the tension on the blade? If the tension is too low on the blade or if the blade is no longer sharp it will cause it to twist and cut crooked.
Nov 21, 2009 | Craftsman Saws
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Bilt that runs off of main drive pulley keep, to deck comes off
If you have an owners manual, verify correct routing of the belt. If this is correct, check all the pulleys with the belt off to ensure they turn freely. Recommend not mowing with the deck in a very low position also. This creates an awkward alingment. Let me know.
May 19, 2009 | Garden
The wires for the stereo are cut
Yes this is not to bad to deal with.. make sure you use quality wire connectors so you don't have problems later with bad connections. you pretty much just have to match the colors from the harness in the car to the ones on your deck. If you don't want to cut off the harness connector on your deck just purchase one that you can connect to your deck and cut the wire ends on the other side of the adapter. The only wires you wont be able to match color for color is speaker wires... for these you will just have to hook them up temp. and test to see that they are connected to the proper speaker output. close.gif Read more >> Options >> answers-logo.gif
Aug 24, 2008 | 1991 Pontiac Sunbird
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
