Question about Kenmore 14417 Humidifier
How much water does model 758.743303 hold
How much water does this humidifier hold
Humidifier model 758.743303. How many gallons of water does it hold? Needing to put water treatment in my water don't know how much water it holds.
Use a container of known capacity, e.g., measuring cup or milk bottle, to fill the humidifier. When full, you can estimate capacity.
Jan 24, 2017 | Humidifiers
No water
well these dont work in winter 1st off if heater is on were u from try to wigle the water buket on it just right so sits in and turns on sum sensor toucjy the way they sit in
Jan 19, 2008 | Honeywell HCM-300T Humidifier
I have a honeywell he220a humidifier . the water drips in but does not get the filter pad wet.
Open the waterline tap valve or may have to clean small orifice that is in line where 1/4" line meets humidifier. Need to shut water off and in screw nut holding copoet line to humidifier
Jan 22, 2011 | Honeywell HE265 Humidifier
Water runs without furnace running
If this is a new problem, on an existing humidifier, then it is most likely a bad solonoid valve. This is the valve that the water line is connected to, and it controls the flow of water to your humidifier.
If this is a problem on a newly installed humidifier, it is possible to have wired the humidifier directly to the transformer power, and therefore holding the valve open all the time.
Hope this helps
Nov 03, 2010 | Aprilaire 700 Humidifier
Water running after heater shut off in humidifier
Hi check power at transformer / valve on water line could be stuck open clean valve out or transformer holding valve open
Dec 31, 2009 | Aprilaire 558 Humidifier
Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Dec 08, 2009 | Kenmore Humidifiers
Water runs out of humidifier drain line constantly(rushes out)
Most modern humidifiers use a constant drain to flush mineral deposits, and to keep the water fresh at all times. This keeps the unit from holding standing water. This keep the water fresh and prevents mold spores from infesting the air in your home.
HVAC Teacher
Jan 27, 2009 | General Filters 1099-LH Humidifier
Honeywell HE220A water not reaching humidifier
Replace the Valve on the unit. Check the small filter inside of it where the waterline attaches first. If its clear and you have lots of flow from the 1/4" line the replace the valve.
Jan 19, 2009 | Honeywell HE220A1019 Whole House...
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Kenmore 14417 Humidifier Logo
71 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
ftykjg
ftykjg
julian hayes
julian hayes
Level 1 Expert
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
